Old 05-11-2015, 12:44 PM   #11
I'm going to take a lot of pics next weekend of our camper so we all know where things are.
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-11-2015, 12:45 PM   #12
I am starting to get dead LED light on the awning now. Placed an email to forest river for warranty
Built-in Controller
Old 05-11-2015, 12:49 PM   #13
Also my compartment key broke off on my rig. Looking for a combination option, just don't know what which size to get. Anyone know which size I should get?? http://www.hannarv.com/P/FJMSecurity...Lockinch/22619
Built-in Controller
Old 05-13-2015, 06:46 AM   #14
Something kind of funny on mine is the lock on the storage under the living room slide uses a different key than every other outside storage lock.
rgvwheeler is offline   Reply With Quote
Old 05-13-2015, 07:02 AM   #15
bubbles's Avatar
Originally Posted by Gripper View Post
not sure if yours is the same I have a 2011, but I go to home depot/lowes for the replacements. not sure on model just go by size. I get the two pack and replace twice a year
The KW1 is not the same as you get at HD, Lowes etc. and not interchangeable with any model at those locals. I think the KW1 canister is the one a lot of people are having difficulty with (unscrewing by itself etc.) and remove it with a bypass and just use an external inline hose filter. There are no issues with the whole house filter type you have.
Old 05-13-2015, 08:41 AM   #16
I have the KW1 and i twisted the canister on and off with no tool. Quite easy to do and it seems like it locks tight too.
Built-in Controller
Old 05-14-2015, 07:25 PM   #17
I installed a Combo cam today. 7/8 is the correct size. Use the curved bracket for a perfect fit. I have the cover coming tomorrow, but at least I got the key one out, given my key broke off. See pics below
ID:	76976   Click image for larger version
ID:	76977   Click image for larger version
Built-in Controller
Old 05-15-2015, 06:41 AM   #18
Hmm that combi is a pretty good idea. I have a dual battery setup with a 5 watt panel. I Had to build a tray for it but it turned out pretty good. I'll take some pics this weekend.
Old 08-23-2015, 08:57 PM   #19
Has anyone figured out a way to stop the stabilizer jack system from sliding side to side when extended?
ncbrit is offline   Reply With Quote
Old 08-24-2015, 05:49 AM   #20
What do you mean by side to side? I have some movement in the floor when the stab jacks are down but I am going to try locking wheel chicks to see if that helps.
