Old 09-02-2013, 09:48 PM   #21
NELA
Weezer's Avatar
Originally Posted by Cajun Happy View Post
You may want to add some type of blocks under your stabilzer jacks. I have found if you do not extend the jacks to far it helps out with the movement.
I read this somewhere on this forum (might have been you) before we left for our last trip.
Told DH about it, he said..makes sense...so we tried it....it *does* help. We just stacked lego blocks under each leg, especially the high end.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 09-02-2013, 10:28 PM   #22
Have found that adding homemade JT Strongarm type cross braces, Bal XChocks and scissor jacks in front of the axles along with an adjustable step support, that 99% of the movement is eliminated. Other than the X Chocks, all are self storing and require minimal effort to utilize.
Old 09-19-2013, 04:53 PM   #23
Mr Coot, why aren't you showing off your handiwork from the mod thread for this issue? That is what I call a solution to this problem, and really makes me want to go find one to do the same thing on my 831FLSS. That looks like a way better investment than strong arms. This support at the axle is obviously needed but not added to these long TT's due to the cost. http://www.forestriverforums.com/for...tml#post467797
The_Rotorhead is offline   Reply With Quote
Old 09-19-2013, 05:00 PM   #24
Originally Posted by The_Rotorhead View Post
Why aren't you showing off your handiwork from the mod thread? That is what I call a solution to this problem, and really makes me want to go find one to do the same thing on my 831FLSS. That looks like a way better investment than strong arms. This support at the axle is obviously needed but not added to these long TT's due to the cost. http://www.forestriverforums.com/for...tml#post467797
OK, here's what I just did after I traded my scissor jacks for a set of electric stab jacks (after another trade at the Goshen Rally)
ID:	40012   Click image for larger version
ID:	40013   Click image for larger version
ID:	40014   Click image for larger version
ID:	40015   Click image for larger version
Old 09-20-2013, 11:41 PM   #25
Plug It Right
We stopped the movement by adding after market permanently installed stabilizers. 8 years and still loving them. Di
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.
Dutch & Di is offline   Reply With Quote
Old 09-28-2013, 07:02 PM   #26
Don and Elaine's Avatar
X2...I also have BAL bars (just like the JT strongarm) with BAL scissor jacks and 99% of the movement is gone.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 92 days in 2017, 94 days in 2018, 108 days in 2019 and 112 days in 2020.
Don and Elaine is offline   Reply With Quote
