Old 06-10-2012, 07:15 PM   #1
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
Camper window
Greeting all.
I'm hoping someone might be able to point me in the right directions.
Someone used my camper as target practice while it was in storage and shot the lower part of our back window. I called the local RV repair place and they told me they would have to replace the entire window, frame and all at a cost of $250+ shipping and labor.
I was hoping someone else might have had this issue and was able to just replace the lower part of the window that was broken.
Images attached.
James
ID:	15092   Click image for larger version
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 06-10-2012, 07:48 PM   #2
Might try e-bay. When I lost my bedroom escape window, found another one for $60.00 including shipping, vs, $250-$400 from other sources. Wayne
wayne anthony is offline   Reply With Quote
Old 06-10-2012, 07:54 PM   #3
remove the lower window since it is the half that opens and bring it in to a glass shop and they will put in a new glass. just have to remove one clip for the crank rod at the window and one screw at the hinge and the window will side right off. a friend had a tree hit a window and did just this. fixed in an hour and very easy.
skidoonut is offline   Reply With Quote
Old 06-11-2012, 07:38 PM   #4
IT Guru
Thumbs up
OMG it was so easy to take out. I just need to see if I can find a glass place that can cut and install a replacement before this weekend.
Thanks for the assist!
James
Old 06-13-2012, 04:00 PM   #5
Smile
Hi- I had my window replaced at Binswinger glass in Texas , the same window as yours ,you need to remember it must be tempered glass and tinted to match the top part. Good luck-my cost 50.00.
Wilkrich is offline   Reply With Quote
