Old 06-27-2015, 08:54 AM   #31
BobHanke's Avatar
The Winegard Wingman ($30.00) is a good addition to the Sensor antenna of it did not come with. About doubled signal strength when installing at home. Goes on without tools in less than one minute. Got the gray one without new rubber feet but old ones went into additional holes easily. This webpage opens with a good view: Winegard Sensar RV TV Antenna
BobHanke is offline   Reply With Quote
Old 06-27-2015, 09:27 AM   #32
crunchman12001's Avatar
Originally Posted by stitcher View Post
We can't understand how it can be the antenna as when we scan the channels we have two to show up but signal is low. Those two channels worked last night and this morning. Could it be where we are located as we were told that GPS's don't work well in this region of Ohio? The GPS couldn't find some towns let alone addresses.
Well, now we are getting down to it...
It would appear everything is fine, you just don't have reception where you are. We are at our seasonal site at Geneva-On-The-Lake, Ohio and we only get 1 channel over the air.
I purchased a stationary satellite dish and a ViP 211z receiver for DishNetwork and have the "pay as you go" plan. It works perfect!
crunchman
2015 F-250 FX4
Old 06-27-2015, 09:28 AM   #33
B and B's Avatar
Originally Posted by Flybob View Post
Almost all OTA TV today is digital thanks to the geniuses in Washington. The down side of digital TV is that you have a picture or you don't. There is no picture with a little snow. And if the digital processor can not get enough data to process the signal, it throws an error or blue screen. Digital signals also are in the UHF range rather then the old TV in the VHF range. These signals do not travel as far and are more susceptible to being blocked by objects. Simple things like rain or wet leaves can make a signal that worked yesterday not work today. Combine that with the low quality TV antennas FR uses on some units and you are doomed to frustration. Alternatives: Get a DVD movie and watch it or upgrade to a Jack antenna. Better yet sit outside and enjoy nature.
We followed in Canada 5 years later and lost TV in most areas we camp. We do have analogue in Northern Ontario and maybe 3 channels in Southern Ontario. We gave up on OTA and use satellite now. We have a Jack, the wineguard with the extra Haddon was useless. The less metal on the roof the less chance of cutting the membrane. The jack is smaller and less weight.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 07-02-2015, 12:17 PM   #34
I'm so glad I found this post. We didn't know anything about a booster until I read this, so the other day we went looking for it. We found it tucked way back in the tv cabinet. We pushed the bottom, scanned the channels on the tv and instead of 1 channel, we get 22, which is all the over the air stations available in our area. Everyone talked about a light coming on when the booster is on but ours doesn't have one.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
antenna
