Old 12-16-2013, 10:49 AM   #1
carpet removal a few questions
OK I have a 2006 bumper pull flagstaff it has a slide and has linoleum in the kitchen area and bathroom and carpet everywhere else. So I have read that it should have linoleum everywhere under the carpet? I will probably leave the carpet on the slid out floor but will removing the carpet from the rest of the floor be OK ? As far as sliding the slide out in and out?
steveinil is offline   Reply With Quote
Old 12-16-2013, 11:55 AM   #2
Should leave the slide room (Flap) and the (Transition area carpet) where the slide room comes in. Youroo!!
Old 12-16-2013, 12:52 PM   #3
TOWTA wants to remove the carpet in the living room also and the slide doesn't leave marks in the carpet. I assume that means the carpet in front of the slide could be removed with no adverse effect?
Old 12-16-2013, 01:01 PM   #4
Yes all the carpet in the living area minus what's on the slide it's self
Old 12-16-2013, 01:45 PM   #5
As long as the (Nylon,Poly?) rub strips are good and adjusted up properly you (May?) be OK without that pcs of carpet in front of the slide? Don't Blame Me if you remove all of the carpet and go down the road and wear the Floor covering from (Road Movement)? Youroo!!
