Old 03-02-2019, 04:48 PM   #1
Check valve issue?
I am having a problem with my fresh/city water . I am hooked up to city water but my fresh water storage tank keeps filling up,over filling. Is there a check valve somewhere to correct this? I have a 2017 FR Flagstaff classic ultra lite
Thanks for any help
COOKCOVEN is offline   Reply With Quote
Old 03-02-2019, 04:55 PM   #2
Flybob's Avatar
This is very common. Yes there is a check valve in the water pump. This should correct it,
Turn off water pump if it is on.
Disconnect city water and open faucet until water stops running
Close faucet and turn on water pump
let water run for a minute or two
shut off water
When pump stops turn it off
turn city water back on and you should be OK. This reseats the check valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-02-2019, 11:07 PM   #3
shut off water
^^^^^^This AND
Don't turn on your water pump while hooked to city water. One or the other, never both.
If City water pressure is less than pump set pressure it will run while hooked to city water. Apparently this caused the check valve to not seat properly on mine and tank overflowed.
There is a check valve assembly you can purchase that will screw on the suction side of the pump, between filter and pump body if you really want to make sure this doesn't happen again.
https://smile.amazon.com/Camco-23303...N5E9PBMKHB3X61
This is for the $5 check valve. Valterra has a brass one for $11
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-03-2019, 10:55 AM   #4
Thank you for your help. I think I am definitely going to look to add the external check valve
Thanks again to both of you guys. Appreciate it!!
check, valve
