Old 06-15-2017, 12:27 PM   #1
control boards keep failing on suburban hot water tank
we have had our flagstaff 831clbss for 4 weeks and dealer already replaced control board and 2 days later the 2nd one went,also to add to the story my neighbor bought his flagstaff 10 days after I did and appears to have the same problem with his control board also both are 2018 models probably made the same week and assembled together,they were bought from same dealer who is fantastic and trying to solve problem with suburban has anyone else had this problem on a 2018?
godlobbin is offline   Reply With Quote
Old 06-15-2017, 12:34 PM   #2
You might check your DC voltage. Maybe your converter is bad and is putting out too many volts and frying the boards?
2011 Traverse LT, 3.6L, FWD
Old 06-15-2017, 12:37 PM   #3
Dealer already checked voltage and was perfect,refrig has been on propane also and has had no problem
Old 06-15-2017, 12:47 PM   #4
My board burned out on first trip out. Also 2018. So far, the second one has worked for two trips.
Age1456 is offline   Reply With Quote
Old 06-15-2017, 08:24 PM   #5
Purchased my TT in December. First trip in April I was running on propane. On the first morning we got up, heard a loud pop and the heater would no longer work on propane. It did, however, still work on 110. It is at the dealer now getting the control board replaced.
DanMistyMiller is offline   Reply With Quote
Old 06-15-2017, 09:07 PM   #6
Iwannacamp's Avatar
I have an SW6DE and our heater made the PDI test and I think one more light then I got a DSI failure light. I checked it out and found a hot spot on the board. Still waiting on warranty information(bought out of town). I wondered what caused the failure. I know dinosaur boards have a fuse on them. I will install and inline fuse holder(assuming I can figure which wire) when/if they supply a suburban board. My RV was shipped 10/19/16
2017 Puma 297RLSS
hot water, suburban, tank, water, water tank
