Old 02-14-2013, 01:04 PM   #21
Herk7769's Avatar
Originally Posted by mjones12 View Post
I've also found that when draining the tank - after removing the anode rod - I don't get much of a stream running out unless I activate the pressure valve.
If you think about it, unless you open a hot water tap inside, how is air gonna get into the hot water tank to replace the water. Even then you have a big drain hole and small pipes.
Popping the relief valve gets you an air hole almost as big as the drain hole.
HAM CALLSIGN - KC3FFW
Old 02-14-2013, 01:11 PM   #22
TURBS's Avatar
Originally Posted by RoadTrip View Post
Hmmm....you've all given my friend alot to think about.
Thanks!
Have him join the forum!
Old 02-20-2013, 07:14 PM   #23
BKennedy's Avatar
Hot water heater
Good info everyone is providing regarding operation of the traditional tanked hot water heater. I decided to go wtih a tankless heater. No bypass, no tank, just endless hot water.... Well, as long as you have propane. May be interested in my post #40 at this link.
2011 Flagstaff 30WFKSS V-Lite Upgrades/Additions
Happy Camping
BK
2011 Flagstaff V-Lite 30WFKSS
2014 F-350 Super Duty Lariat 6.2
BKennedy is offline   Reply With Quote
