05-10-2015, 08:14 PM
Could not uncouple
I just purchased a 2015 Flagstaff ultralight DS21. Brought it home from dealer and ... could not uncouple. I've worked with trailers my whole life and did all the tricks. Left coupled and slid out receiver. Is there and more information on this problem over the past 12 months ? I'll call the dealer on Monday.
05-10-2015, 08:46 PM
I think it would help to know exactly what happened to you.
Were you not able to lift the latch?
Were you not able to release the jaw?
Were you not able to get the ball to drop?
Were you not able to release it even with the receiver out?
I hope this type of detail would get you some better answers.
05-10-2015, 08:53 PM
The latch lifts out of slot. I never saw full release position but I don't think it is vertical. It feels like gate is not opening enough. Crank post to plenty of pressure. Jumping on bumper. Nothing. Pulled receiver still attached.
05-10-2015, 09:00 PM
Since it is brand new, my first guess would be the manufacturer/dealer lubed nothing. If you can get some of (whatever the hitch manufacturer recommends for) lubricant in there it may help.
05-10-2015, 09:02 PM
You may have already tried this but when it happens to me I chock both wheels on the trailer and give it a little forward jerk with the truck. I have to back up an incline and the ball exerts pressure on the back of the hitch and wont let it release. The trailer should be firmly on the hitch before doing this. But you probably already knew that.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
05-11-2015, 04:26 PM
What did the dealer say?
05-11-2015, 04:33 PM
Did you get back up under there and try to back off the coupler adjustment bolt? It wouldn't be the first time someone had a coupler set for a 2" ball on an actual 2 5/16"'r.
05-14-2015, 02:20 PM
I've had this problem with my Windjammer and Equalizer hitch since day one. I think it's the angle of the ball, but it's set where it needs to be to level the truck and trailer.
What seems to work for me when this happens is to chock the trailer well, and then back up the truck very slightly so as to take pressure off of and fully release the tension on the latch. I also make it a point to lubricate the latch and ball before each trip.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
05-14-2015, 03:49 PM
Dealer said bring it back if I can not get it ( 2 hours one way ) but they seemed good. I am attacking it this weekend, just have not had time this week. I don't remember seeing an adjustment nut in there like on smaller trailers. I can see the "gate" and will try to tap that back if possible. This is new reciever and WD setup so even though trailer has been off and on a few times on their vehicles it is the first hookup with this ball and receiver.
05-14-2015, 03:54 PM
AKA: 'tiredTeacher
I recommend the judicious application of an impact generator.
(Translation: Hit it with a hammer.)
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
05-14-2015, 04:00 PM
I had the same issue with a different model hitch and RV and chocking the trailer wheels and moving the tow vehicle slightly forward worked. Mine wasn't greased and will be the next time. We had the same issue with boat trailer in the past.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
05-14-2015, 04:04 PM
Same as above.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
05-15-2015, 06:17 AM
Got it. My turn to wear the idiot hat. When I started crawling underneath I noticed that the release lever slides up and back more than I thought. It may have been binding when hooked up but without the trailer attached it slid right back and the hitch dropped out. I'm going to grease it all up and hope for the best. Thanks everyone for your help. JW
05-15-2015, 06:31 AM
Good deal! Sometimes I think they (DIP/DUNK) them in Thick Black Paint! Youroo!!
05-16-2015, 03:19 PM
You are in good company IMHO. I had the same "problem" with my new FR trailer when I picked it up this year. Just hadn't seen a ball latch that had to slide back before and it took me awhile to figger it out.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
05-16-2015, 04:04 PM
Don't skimp on the grease... especially the nooks and crannies in your coupler.
05-16-2015, 04:24 PM
And put a few dabs of grease on your shirt and pants. Just to get in the practice!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
05-23-2015, 03:28 PM
2016 Rockwood Ultra-Lite
Making a note of this because it will probably happen to me when I bring the new Rockwood home for the first time.
Jim and Connie w/3 lb. Chihuahua= Nugget
2016 Rockwood Ultra-Lite 2608WS
2004 Dodge Ram 2500
05-26-2015, 08:05 AM
happened to me one time early on too..Did everything I could think of including the hammer. After about an hour of trying it FINALLY dropped off with much fanfare. I lubed well and it has never happened again..knock on wood!
2014 Flagstaff 21FBRS
2013 Toyota Tundra 5.7
