Old 12-03-2016, 06:44 AM   #1
4Daughters's Avatar
Counter extension mod ideas
The new Flagstaff/Rockwods have the counter extension that is now attached and just folds down out of the way. I have a 2017 but my extension still has to be removed and stowed. If you have the newer model could you please post a picture on how this is being done? I would like to do this to my TT. Thank you!!
4Daughters
40 miles NE of Atlanta, Ga
2017 Flagstaff Classic Super Lite 831bhds
2016 Chevy Silverado 1500 max tow package
4Daughters is offline   Reply With Quote
Old 12-05-2016, 04:31 PM   #2
Left Coast
Under the bed?....Wife doesn't use it as it somewhat blocks drawers
Old 12-05-2016, 07:10 PM   #3
4Daughters's Avatar
That is where we usually keep it. But that is a pain. We like to have it to dry dishes on as well as keeping snacks during the day. Would serve us better if it was folded down and easily stood back up from the folded position.
4Daughters
Old 12-05-2016, 07:12 PM   #4
Left Coast
Do you have a dinnet or a stand alone table?
Old 12-05-2016, 07:14 PM   #5
4Daughters's Avatar
U shape with stand alone.
4Daughters
Old 12-05-2016, 07:35 PM   #6
Islander's Avatar
4Daughters...
I don't know the counter layout of your Flagstaff....
But, if you have any counter overhang area that has nothing like drawers or cupboard doors under it ... I will brave the winter weather tomorrow if someone would like to know where & how I stow our removable counter section.
We use it a lot , yes it is in the way of the drawers while in use, but we still can access them...so I made some hanging brackets and keepers to store it under the counter overhang where the 2 bar stools are meant to be used.
It's secure under way and better than under a bed or in a closet.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 12-05-2016, 09:02 PM   #7
4Daughters's Avatar
This is what my layout looks like. The counter addition goes on the end near the sink.
4Daughters
Old 12-05-2016, 10:05 PM   #8
Islander's Avatar
So what is on the other side of the cabinet inline with the kitchen faucets?
Also how much of an overhang does the counter top provide on that side ?
In order for my method to work and to look ok you would need the same amount of overhang as the "thickness" of the counter extension 'plus' the amount the "extension supports" take up..... in other words the Over-all supports and extension thickness ...equals overhang.
I will try and post my set up tomorrow.
Islander
Old 12-05-2016, 10:09 PM   #9
iluvlcy's Avatar
We put some wooden screw on legs on ours that way I can move where I need and sometimes use outside when using crockpot etc. It stows behind bathroom door when not in use.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 12-05-2016, 10:13 PM   #10
Left Coast
They make double ended screws for legs to remove legs if more area for storage is needed
Old 12-06-2016, 03:44 PM   #11
Islander's Avatar
Counter extension storage location
I am not sure if this will help '4Daughters' or anyone...
But I will post my setup just in case it might help someone down the road.
I know how everybody likes pictures.. so here ya go
I stayed with the same mounting supports that came with the counter extension and the same adjustable leg as well.
- Picture 1 shows counter overhang with extension in stored position.
- Picture 2 shows front view of counter extension in stored position.
- Picture 3 shows what I used to hang the counter extension (using the mounting hardware it came with) It was a piece of 1/2"X1/2" aluminum cut the width of the table and slots cut to fit the mounting hardware, screwed to the underside of the counter overhang.
- Pictures 4,5, 6 & 7 shows what keeps the counter extension in place during travel.
To help explain: The top 2 pieces of wood mounted with spring hinges (cupboard door hinges) fit tight against extension..at the bottom is a rocker door catch to hold the extension from swinging out.
A small piece of pool noodle is taped to the folding leg to provide protection and a little soft resistance for the catch at the bottom.
I'm not saying this is for everyone or it is the best set up but it is a handy secure location and it works for us.
I'd be happy to answer any questions if I didn't make it clear enough.
Islander
ID:	126271   Click image for larger version
ID:	126272   Click image for larger version
ID:	126273   Click image for larger version
ID:	126282   Click image for larger version
ID:	126284   Click image for larger version
Old 12-06-2016, 03:51 PM   #12
That's some great use of the ol' thinkin' cap Islander.
Good job all the way around!
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 12-07-2016, 10:51 AM   #13
mcmartinez's Avatar
Extension Mod
I just mounted it with 2 hinges where they use to hang. I no longer need to stow it. It folds up and down when I need, or not.
Name:	Ext Mod 1 (2).jpg
ID:	126326   Click image for larger version
Name:	Ext Mod 1 (3).jpg
ID:	126327   Click image for larger version
Name:	Ext Mod 1 (1).jpg
Mario Martinez
2703WS Rockwood Super Lite (6,400 Dry weight)
Tow Vehicle - 2016 Ford F150 Lariat Platinum Limited
3.5L EcoBoost (12,200 Towing Capacity)
mcmartinez is offline   Reply With Quote
Old 12-07-2016, 10:52 AM   #14
mcmartinez's Avatar
Sorry, they uploaded sideways. Let me know if I need to upload them again.
Mario Martinez
Old 12-07-2016, 05:39 PM   #15
Islander's Avatar
'mcmartinez'....
That works !
Good going.
Islander
Old 12-07-2016, 05:44 PM   #16
VERY nice, Mario!! Where did you get the matching counter-top material?
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 12-07-2016, 06:09 PM   #17
4Daughters's Avatar
They both look great!
4Daughters
Old 12-07-2016, 06:12 PM   #18
mcmartinez's Avatar
The extension came with the trailer. I just mounted it with hinges because storing the extension was a pain in the but.
Mario Martinez
Old 12-07-2016, 11:38 PM   #19
I have a pic of my old trailer where I put an extension on the end of the counter area. It was there for the entire 23 seasons we had the trailer. The shot was taken just before we sold it for out new one. You would have to figure how to attach it to your Corian counter, but, the idea was to have two angled pieces attached to the bottom of the extension which came up and fitted into slots in the side of the counter. Since I had to brace the angled pieces, I used a dowel and added a second shelf under the first one. The whole thing folded down (in the picture you see a towel which is the pad for the TV we stowed under the extension during towing - you can see the mount on the wall). In your case you would just have the two extensions because you are needing to open the drawers. Check the underside of the counter and see if there is enough room to glue a piece of board to attach the piano hinge for the extension. I built mine out of scraps and plywood, but, it may give you an idea for yours. I am going to try to attach the picture so you can get an idea how it was in there. The extension folds up and the legs go into a slot with the second shelf resting on the down crosspiece. It set up in seconds and we used it for toaster, pots, dishes, etc. storing papers and such underneath it. When we folded it down the hook kept it in place and also provided enough clamping power to hold the TV in stored position. Hope this helps.
ProfChuck is offline   Reply With Quote
Old 03-26-2017, 02:27 PM   #20
YES!
THIS is is exactly what I need! Thanks for posting
CampingRDH is offline   Reply With Quote
