Old 04-29-2014, 03:51 PM   #1
Dovetail's Avatar
Countertop delamination
Some delam of the kitchen countertop showed up.
About6" long 2" wide. 4" away from sink.
Any way to get it refastened/glued?
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 04-30-2014, 06:51 PM   #2
Dovetail's Avatar
Any thoughts?
2006 F350 SW
Old 04-30-2014, 06:56 PM   #3
markb5900's Avatar
for that type of thing you want to use contact cement, but it is HARD TO DO UNLESS the entire thing is up.
Using contact cement, once it touches it is THERE for ever.
Put 1/4" dowel rods under it and apply the contact cement to both sides, then pull the rods out and use a j roller to press it down.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 04-30-2014, 07:15 PM   #4
Dovetail's Avatar
Think i could get some contact cement in with a syringe? That stuff is pretty thick as I recall.
2006 F350 SW
Old 04-30-2014, 09:16 PM   #5
Slympicins's Avatar
You could try a long putty knife to smear it around and push the contact cement underneath the laminate. I have done this on do or twice with good results. Use the roller to press down and push out the excess contact cement. I would rather fix that than take it back to the dealer to do. You will probably do a better job and you know it will be done right. As a last resort, find a reputable cabinet repair person in your area to give you an estimate.
Good luck to you.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 05-01-2014, 07:10 PM   #6
NELA
Weezer's Avatar
I had a counter top delaminate years ago in my (then) S&B kitchen. I came up with the idea of applying heat to re-stick the glue.
So,
I put a double layer of bath towel over the spot and used my clothes iron on high. It re-stuck and never came loose again.
Again, that was years ago and different adhesive may be used now.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 05-01-2014, 07:45 PM   #7
leencharlotte's Avatar
My parents had an issue with a portion of their glue down hard wood floor that released in a small spot in the middle of the floor. There was a kit where you drilled a hole and applied glue with a syringe. Not sure if they have same for countertops but check a local countertop store as house/camper would prob be same fix
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 05-01-2014, 10:36 PM   #8
Dovetail's Avatar
Thanks for those thoughts. DW was talking about her hairdryer for some heat. Ironong sound good. Will try a countertop place fir info.
No room to slide anything in. Kinda in the middle and i dont want to slice it to gain access.
2006 F350 SW
Old 05-03-2014, 08:58 AM   #9
NELA
Weezer's Avatar
I forgot one step of my repair;
After applying heat with the iron, leave the towel on and add something VERY heavy for a few hours while the glue cools. (IIRC I used a new/clean cinder block.)
And yes, the delamination I repaired was a bubble in the center of the counter top.
Old 05-04-2014, 07:29 AM   #10
Dovetail's Avatar
Back from trips, so going to iron next week. Thanks
2006 F350 SW
delamination
