Old 08-24-2018, 09:21 AM   #1
thedarkside's Avatar
Cover Questions
As we head into the first winter with my Microlite 25BHS, I am investigating a cover to protect it during the New England winter. I'm researching different brands of covers (ADCO, PermaPro, etc.), but have a couple questions:
1. Should you also have individual covers for AC units, etc. or does the RV cover provide enough protection?
2. Do you cover the hitch/power jack or just the main box? The battery and propane tanks will be stored in an enclosed area out of the elements.
3. Any suggestions of which cover is best? (this one should provide about 100 opinions )
Thanks!
thedarkside is offline   Reply With Quote
Old 08-24-2018, 09:36 AM   #2
007matman's Avatar
The RV cover is good for anything that's on the roof of the camper. You may need to retract any antennas or lay them flat. You don't need individual covers for ac units, etc. They're typically large enough to compensate for those items.
If your camper is under a roof you probably don't need to cover the tanks or tounge. However, most covers have some extra room and you likely can cover those items (as well as the spare tire) if you want to.
I really like my Adco cover. It's the one with Tyvek on the top. Sides are breathable and the top is mostly waterproof. Purchased off of Amazon and it's available in multiple sizes.
ADCO 34844 Designer Series Gray/White 26' 1" - 28' 6" DuPont Tyvek Travel Trailer Cover https://www.amazon.com/dp/B00T367Z7I..._iGbGBbTHBXV0R
007matman is offline   Reply With Quote
Old 08-24-2018, 09:42 AM   #3
Scoundrel
HangDiver's Avatar
This^^^^ I have the same cover and will use it again this year. Remember to poke a hole into a few tennis balls and put them over anything that sticks out from the "box" so as not to puncture the cover.
Good luck
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 08-26-2018, 11:39 AM   #4
Navy06RET
dascribner's Avatar
Thanks!
I use Eevelle Goldline from National RV covers, warrantees up to 5 years depending on type purchased. Had some tears after 2 years, sent in pics, immediately replaced. https://www.nationalrvcovers.com/?ut...t=1RV%20Covers
dascribner is offline   Reply With Quote
Old 08-26-2018, 12:26 PM   #5
Just as confused as you
Scrapper's Avatar
One problem I found with covers is they let mice climb up to the side vents for the refrigerator and in my case into the hole to manually operate the bedroom slide. The little buggers got into the side skirting and chewed the wires for my step light and one of the side markers. For the fridge they climbed up to the upper side vent and chewed through the fiberglass screen and made themselves at home.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-26-2018, 12:40 PM   #6
Navy06RET
dascribner's Avatar
I use these aluminum fridge vent covers on my 21FBRS: https://www.amazon.com/Camco-Flying-...70_&dpSrc=srch
Old 08-26-2018, 12:48 PM   #7
Scrapper's Avatar
I hot glued fiberglass screen to the inside of the vents to keep hornets out. At the time I didn't think about the mice climbing up the inside of the ADCO cover to get to the vents.
Richard & Jill
cover
