Old 11-16-2016, 02:16 PM   #1
Covers
Does anyone have a recommendation for a cover for our new travel trailer?
bmcevers_13 is offline   Reply With Quote
Old 11-16-2016, 09:01 PM   #2
WFD
Do a search in the threads, hotly discussed topic and there will be loads of reading with both pros and cons. After that if you still convinced to cover, the cover of choice you will will likely be the Adco.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-16-2016, 09:46 PM   #3
cphubert's Avatar
We cover with a Adco / camping world cover, if you decide to cover buy the extended warranty as we have replaced ours with it. I am pro cover not tarps or open (no cover) due to ice build up. No tarps because they do not breath. Moisture and freezing weather are the things that cause damage over time. Everyone has their own opinion on covering or not. Lot of info on forum.
cphubert is offline   Reply With Quote
Old 11-16-2016, 09:49 PM   #4
Platokidd's Avatar
https://classicaccessories.com/rv-pe...-trailer-cover
Strong light weight easy to handle. I've used this cover for 3 years now without any problem to cover or camper.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 11-16-2016, 10:36 PM   #5
WFD
Wind will also be your worst nightmare, so if you choose to cover it has to be well secured, another reason for avoiding tarps, because you will never get it tied down enough so it doesnt have movement in it, thereby causing rubbing and wear. And as cphubert said...they trap moisture, which will be a disaster.
cover
