Old 10-27-2013, 04:54 PM   #1
Difficulty removing lens off LED lamps in Flagstaff 27 RLWS
My RV has LED lamps as shown below. If you have these lamps - What is the best way to remove the lens?
I need to remove the little styrofoam debris trapped there. Gently prying I was able to remove only one lens. The others hold on so firmly that I don't want to rip the fixture off the ceiling. I used a small screwdriver at the little slots (2 each side) but based on the design this is not the solution (hence the failure of the others). The slots are not where the little tabs on the inside of the lens are. Besides, the screwdriver puts little dents in the ceiling.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 10-27-2013, 05:02 PM   #2
dannyabear's Avatar
I've got the same problem.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 10-27-2013, 05:52 PM   #3
I think the lens itself comes off, not the entire fixture.
Old 10-27-2013, 05:56 PM   #4
dannyabear's Avatar
I want to remove the entire fixture over the bed, so I can drill a hole and install a pull chain switch so DW can reach it.
Danny & Darlene
Old 10-27-2013, 08:48 PM   #5
Actually when I did get the one to come off I looked closely at the inside. The clear lens is not separable from the white part. The entire thing you see in the picture is one assembly that fits over a steel base shaped similarly but slightly smaller.
Regards,
Wayne
Old 10-27-2013, 10:15 PM   #6
kz08h5's Avatar
Looking at the picture of the assembly, pry on the white part not the clear lens.
Wmoses is correct. When you do the prying put something between your pry tool and the ceiling. This will protect the ceiling from nasty pry marks.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 10-27-2013, 10:33 PM   #7
That explains why I got one without the lens from Capt Mike when the techs at Goshen changed all of his out. The lens was missing from that one fixture. Evidently they didn't know either.
Old 10-28-2013, 04:34 AM   #8
fonzie's Avatar
Here is a similar thread showing when lens is off......
Interior oval light lens removal
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-28-2013, 06:07 AM   #9
Thanks fonzie. This sounds hopeful. Don't know why they had to make it so difficult.
Regards,
Wayne
flagstaff, led
