Old 12-01-2010, 09:19 PM   #1
mhbell's Avatar
Send a message via Skype™ to mhbell
Question Direct TV remote codes for Venturer TV
Has anyone been able to find the remote codes for the direct TV remote. I have a venturer TV in my 2009 Flagstaff 8528RLWS. Direct TV doesn't list the Venturer TV to program their remote.
Tia
Mel
Problem solved see the next thread.
mhbell is offline   Reply With Quote
Old 12-01-2010, 10:19 PM   #2
mhbell's Avatar
Problem solved
Here is what I did. I went to direct TV Link: DIRECTV Remote Codes and followed the following instructions. It worked for me.
Mel
Instructions follow
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Old 12-15-2010, 09:42 AM   #3
We have a new Cedar Cedar Creek fifth wheel with a Jenson TV.
We added Dish network sat service and can not program the Dish remote to control the TV. We have tried every code, even the "30 minute" search etc. with no luck.
A Jenson tech told us that most likely no remote will control that TV.
2016 Cedar Creek Cottage destination trailer
2017 Chevy Silverado High Country
gmccall is offline   Reply With Quote
Old 12-15-2010, 10:28 AM   #4
mhbell's Avatar
You have to be very careful when trying to find the right code. It took me two tries with my Direct TV Remote before I got it. Another thought is if you can get a universal remote that will work with the Jensen TV and program it for the Dish Receiver as well as the tv.
flagstaff
