Old 02-20-2015, 08:39 AM   #21
My new trailer bought in July has the onboard filter and we do have it installed. I like others do not drink the water and use bottled water but use it for cooking and other functions. May be silly not to drink it as I use it for brushing my teeth but just what we are used to.
I have read in the Sandpiper forum that the type of filter used on the 2015s requires a pepritory filter, I cannot confirm but trust much of what I read on here. I will check in the spring for a filter and if it is costly, I will do what many others with this brand have done, cut out the factory installed filter and installed the generic Home Depot whole home filter. Also, some with the style filter I have experiance the filter spinning off with pressure, I have experienced this and most have also chosen to swap out the setup with a generic brand because of this.
2015 Sandpiper 30IOK
2014 Ram 6.7 CC DRW
2006 Charger RT
X96mnn is offline   Reply With Quote
Old 02-20-2015, 08:50 AM   #22
camper1999's Avatar
We do use the campground water. We have the whole trailer water filter and I have installed, at the kitchen sink, a drinking water filter systems. We never had any issues.
2011 GMC 2500HD Diesel
Old 02-20-2015, 09:31 AM   #23
B and B's Avatar
The key to the internal filter is using the wrench to tighten it. If this is done it doesn't loosen, that is right from the manufacturer. I spent some time talking to him last summer at Goshen.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-20-2015, 09:47 AM   #24
I never talked with the manufacturer but it does state that in the manual. I may be doing it wrong, I had tightened it to the point I snapped the plastic wrench that came with it. The dealer replaced the housing as they experienced the twist off as well, I only removed it this time when I winterised the camper. Will need a new filter in the spring and based on the cost will decide my next step.
When it first happened I received a new wrench from the dealer and had actually used it to keep the filter on until I could bring the camper back. I tightened the filter then placed the wrench on it so that it was tight against the wall. When I turned the water the filter did start to turn off but the wrench tight against the wall would not let it. Held fine for two weeks before I brought it back.
2014 Ram 6.7 CC DRW
2006 Charger RT
Old 02-20-2015, 09:50 AM   #25
geotex1's Avatar
This is true! However, the reason the canisters fail is because many do not understand that the o-rings must be replaced regularly, especially when heavily treated water is run through the system. The o-rings become less compressible with age and also shrink. The natural result is they get cranked down tighter so they don't loosen and seal. Doing this, especially with the mechanical advantage afforded by the wrench, and you are absolutely going to end up with a canister broken at the neck below the threads! I changed my cartridges 2-3 times a season as needed, and a new o-ring was installed every other season. A pliable seal requires little torque to seat the canister leak-free and so that it stays put.
geotex1 is offline   Reply With Quote
Old 02-22-2015, 09:00 AM   #26
Slympicins's Avatar
I agree with drinking the water. Our CG water is completely fine to drink. After all most of us drank out of hose when we were kids and we are doing fine today. Our TT wasn't but a few weeks old when the canister backed out and flooded. After that I would not trust it for good reasons. I use the in line filter with no pressure loss. http://www.campingworld.com/shopping...r-filter/18478
I see a lot of folks using this in line filter with the stand out side. http://www.campingworld.com/shopping...r-filter/56670
I would rather filter out the sediment before it settles in the system. I understand the filtration system works for most folks but it's just a matter of time before it fails.
The small tabs inside the filter housing after winterizing several times wore down and would not hold the canister any longer. They are cheap housings. Getting the filter out when winterizing was yet another issue. We camper during the winter and had to winterize when we left. Spilling water everywhere. That too was not fun. They didn't exactly place ours in a wonderful place.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 03-10-2015, 03:13 PM   #27
We are considering changing out the existing water filter in our TT with a Dupont Valve in Head Whole House Filter. The carts are less expensive and with the in head valve we can select to have the water pass through the filter, or bypass the filter altogether (great for winterizing) or turn off the water all together. With the in head valve I think it will also be easier to change the filter by bypassing the filter. Any comments?
Gary Hadden is offline   Reply With Quote
Old 03-11-2015, 06:27 PM   #28
Slympicins's Avatar
Sounds like a great filter however will it slow down your water flow like most home filters?
Chuck and Joanne
Old 03-12-2015, 02:54 PM   #29
The filter says 5.0 GPM flow which I thinks is faster then the KW1. I hope so.
Old 04-29-2015, 07:32 PM   #30
Mfr instructions also says to grease the o ring with silicone grease (food grade of course). I wonder how many don't do this or tighten the canister until they feel the detent click.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
danking49 is offline   Reply With Quote
water, water filter
