Old 09-23-2016, 11:15 PM   #41
I have used the DISH tailgaters for 4 or 5 years.
Love 'em.
But don't like going out in the rain, screwing the coax into the fittings, doing so in the dark, etc.
2016 Flagstaff 26FKWS
So....I ordered the "feet" for the dish, and.....
....am chickening out on the permanent mounting.
1. Is the roof plywood or something that I could drive mounting screws into ?
2. I have experimented and know that the old "point the handle north" doesn't matter any more, just takes longer to find the sats.
3. How does one "fish" the coax down the walls to the inside ?
4. Sealer for the feet ?
5. What did I miss ?
Thanx to all
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 09-24-2016, 12:23 AM   #42
Telstar's Avatar
Most roofs are plywood. Mount the Tailgater as close to center line as possible making sure to mount in flat area (maximum 2 degree allowed). Read directions as to how close to other objects you can get. I've pulled cable through the attic of several RV's with no problem, interior walls should be OK. Gain access by removing vent shrouded and lights. As far as aligning house type dish, DIDH for my RV and dish align phone aps make it a snap.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 09-24-2016, 07:05 AM   #43
NMWildcat's Avatar
I would think twice about a permanent mounting for your tailgater. I had two sets of friends who did that for the same reasons you mentioned. After trying it awhile they both either unmounted them or bought/made a ladder mount that was easily detachable to move the dish away from obstructions. The fella that did the ladder mount bought one and modified it. He leaves it there during travel and it seems to work very well for the last 18 months.
Scott and Liz - Southern NM
Old 09-24-2016, 11:04 AM   #44
Were their reasons strictly to "avoid obstructions" ?
Old 09-24-2016, 11:18 AM   #45
Ford Idaho's Avatar
In my case yes.
Bought a ladder mount, first place we went the ladder was so buried in the trees it never saw daylight while we were there.
Got back home and ordered a tripod.
With 45 feet of coax I can place it to face open sky with ease.
Old 09-24-2016, 11:48 AM   #46
Blog: RVroadtripper.com
hbillsmith's Avatar
Have the King Controls version of Dish Tailgater and it has worked really well. Finding open sky is usually the biggest pain when setting up. I thought about permanent mount many times and to test my theory, a few times when I camped I set the Tailgater on the roof (on top of a rubber mat) and used bungy cords to secure it to the ladder (weather was nice so not really worried about blowing off, but secured it anyway). I found that about half the time, I couldn't get a signal and ended up moving it back down.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 09-24-2016, 11:56 AM   #47
NMWildcat's Avatar
Originally Posted by Ford Idaho View Post
In my case yes.
Yep.... Open sky is important and if you have a stationary dish that is obstructed you either move your rig or watch the neighbor's TV😁.
Old 09-24-2016, 10:30 PM   #48
Thank you, one and all, for pointing out the necessity of open sky.
You will note, in my original Q, I have been using the TG for five years.
My concern is NOT whether I should mount it.
It is how to do it.
Old 09-25-2016, 05:17 AM   #49
Ford Idaho's Avatar
It is how to do it.
The ladder mount came with a base plate and an aluminum shaft which I used.
I bought this tripod.
https://www.google.com/url?sa=i&rct=...74884639461424
I placed two rubber rings around the 1 inch shaft and then place it in the upright tube of the tripod.
I will post some pics after day light shows up.
Old 09-25-2016, 11:05 AM   #50
Ford Idaho's Avatar
satellite
