Old 04-29-2012, 12:16 PM   #1
Domestic A/C
I have a 2008 flagstaff with a domestic ac unit. The ac unit will run constantly unless you set the temp above 90. Has anyone had this problem? And if so what would be the fix. Thanks!
hgodsey is offline   Reply With Quote
Old 04-29-2012, 01:26 PM   #2
showtime0022's Avatar
If you have the old style thermostat(spring). Best thing to do is the mod. 20 bucks worth its weight in gold... Look up hunter or honeywell mod.
showtime0022 is offline   Reply With Quote
Old 04-30-2012, 09:51 AM   #3
Usually, the fan runs all the time. The compressor will cycle off and on, but the fan is continuous. It is not like a house unit, where the fan will come on and off.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
