Old 07-04-2016, 10:52 PM   #1
Dometic Toilet
Hello from Corpus Christi, Texas, where even bald guys have bad hair days! I am heavy-set and broke the Dometic foot-flush toilet from its floor anchor. There appears to be only one anchor bolt on the bottom left side of the toilet. The toilet now wiggles all over the place. How do I fix it? Muchas gracias!
Hector517 is offline   Reply With Quote
Old 07-05-2016, 10:26 AM   #2
Head Rambler
There should be more than one bolt holding it down.
I would take the toilet up and make sure the flange isn't broken from the plumbing.
You can then see if you can replace the bolt and add the other one that should have been there to begin with, or if you need to reposition the toilet a little to get the proper bolts in there.
Gotta go campin!
Old 07-05-2016, 10:37 AM   #3
Too old to be too smart
SpringerPop's Avatar
Unsolicited advice:
When replacing hardware, use stainless where you can.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
dometic
