Door Lock problem
Not sure if anyone has this same problem or we are just weird. Our trailer only has one entrance door. The outside of the door has two key locks, one is for the dead bolt lock, the other for the latch lock. On the inside of the trailer there is only ONE lock switch, which appears to lock both the dead bolt and the latch lock. This lock switch is at the bottom of the inside door latch. On occasion the door will lock behind us, not sure if it’s from shutting the door too hard or somehow partially moving the lock switch on the inside when leaving and it trips when the door is shut. Has anyone had this same problem?
