11-16-2015, 08:39 PM
Draining the Water Heater
Can someone give me an easy explanation on how to drain the water heater. I was told it was good to do after every trip.
11-16-2015, 08:42 PM
Take a look at this link. It should help. It is really easy.
I don't know if I would do it after every trip, but I would if it was going to sit for any length of time. Definitely emptied as part of winterization.
11-16-2015, 11:07 PM
Ambassador
I don't drain mine except when I winterize. I do use it a few times a month though in season, I'm always going some where. If I used it sporadically then yeah I'd drain it because it would get nasty...
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
11-17-2015, 05:29 AM
I do not have to winterize but the plan is to use it once a month for 2 or 3 days. Would draining still be recommended.
We are on Florida and will go north in May.
11-17-2015, 05:57 AM
I would drain it if your only going to use it 1x a month. Not that hard..
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
11-17-2015, 06:28 AM
"On the road again"
Just MAKE SURE you always remember to plug it back and refill it before you use it next time with electricity or you'll burn up the electric element very quickly.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
11-17-2015, 06:44 AM
Thanks. I remember when I had a boat. I saw a guy put his boat in the water with a trailer. He took off and shortly did a 180. He forgot his drain plug. Funny but not funny.
11-17-2015, 07:42 AM
If you're using treated city water, I don't believe it's necessary to drain after each trip. If you're on well water I would probably would drain it after each trip, unless using the rig monthly.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
11-17-2015, 12:24 PM
pick up a petcock drain plug at your RV dealer. It replaces the plug on atwood water heaters. (Plastic) It is all brass. Then just open the petcock to drain it when you need to. No wrench needed. If you have a Suburban WH then you will not be able to do it because of the rod.
needed to save the tank.
11-17-2015, 12:38 PM
If you have a suburban WH it would be a good idea to drain it occasionally and check for anode erosion. I usually put the anode back in after draining so insects will not get into the system. By the way, it would be prudent to open the relief valve before you take the plug out or you will suffer the consequences. It also helps to open the valve to let it drain faster, make sure the water is not hot also.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
11-17-2015, 12:45 PM
Thanks for all the info.
11-17-2015, 12:51 PM
doesn't the Water heater drain if you open the low point drains? That's how I drain mine if its gonna be longer than two weeks..
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
11-17-2015, 12:56 PM
I've been wrong before but I believe they do not. The only way to drain the WH is removing the plug/anode rod.
11-17-2015, 01:02 PM
I am not positive either, but i know that the hot water drains for a considerable longer time
11-17-2015, 01:27 PM
We have a 2014 Georgetown XL have had it a yr. Its been in the shop more than out. Everytime we take her out seemed the toilet wasn't able to receive water to flush. One time we flooded out. Take her to the shop and it was the screen that was full of gunk. Was told it was the lines to be flushed out. Factory had pushed lines with strofoam, etc. so they repair it. Nov 2015 she goes out of warranty. Just take her in. This time they tell us its our fault. Sand in the lines. Must be where were camping. Funny story change in there theory. Tell us to use outside filter system. Were camping with 10 others and there NOT having the same problem. Long story short. We use this forum and see it could be the water tank and anoid rod. So we call and tell them. OH NO they tell us. So I call FOREST RIVER. Still fighting it. Bought camper at Berryland in Hammond LA, Refuse to pay for there labor. Update. There fixing it or a one time courtesy. After a whole year of toilet flushing issues and sediment in screens don't you think they would had checked the hot water tank. Not leave it up to the owner researching the forum??
11-17-2015, 01:43 PM
Turn water on in the spring turn off in fall and winterize the empty water tank. To much thought and doing things that don't need to be done. That's my official answer to your good question the rest is just me venting take no offense. People in general cause their own problems, IE: Empting water heater all the time, results burnt out elements. Scrubbing the bottom of their tires, Duh tires are supposed to be dirty, Scurbing the bottom of their boat every time they take it out of the water, Duh it's supposed to have some water borne dirt on it, covering their A/Cs in the winter causing condensate to build up and rot it away, it's supposed to be outside. Many more but other things to do. Got to go uncover my car again got to go to the store, dam I just covered it this morning when I came home from picking up the paper. OH Well. Go ahead I'm ready to accept the baloney coming from all the OCD people.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
11-17-2015, 01:50 PM
If you are going to do this on a Suburban WH, you will need a reducing bushing 1/2 x 3/4 NPT for the install. Camco makes a sacrificial anode rod with the petcock on it. You'll need the bushing here as well. Makes it very easy to drain
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
11-17-2015, 03:23 PM
My current 5th wheel will drain about 85% of the water from the WH if I open the low point drains. It really depends on how they routed the plumbing from the factory. I have to remove the anode rod to get the last 15% out. Even then, about 5% stays in the tank with the anode rod removed. To totally drain, I have to insert a small hose and siphon the last little bit out.
If you are just wanting to drain the majority out just for the down time between uses, I would open the low point drains, open a hot & cold tap, let the system empty, remove the anode rod/plug and see how much remains in the tank. If you are satisfied it empties 75-85% of the WH capacity, I wouldn't be taking the anode rod/plug out each trip after that. Just my 2¢.
Winterizing... different story.
11-17-2015, 05:03 PM
Draining water heater
No need to drain water heater unless you are winterizing or just storing for more than a couple of months just a waste of your time no benefit at all
11-17-2015, 05:27 PM
If you have an Atwood, you can replace the plug with an adapter with a drain valve on it ( easy to make yourself or buy one). Makes draining WH as easy as opening valve ( also keeps water and WH gunk off side of RV).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
