Old 12-22-2015, 11:28 AM   #1
Dry Weight of 2016 21fbrs
The dry weight of my 21fbrs is 3550 lbs. I have yet to see one that is lighter than mine. Makes me think they left something off. Just wondering what the dry weight of everybodies is. I pull it with a 2015 tacoma 4x4 with a towing capacity of 6500 lbs.
scottfarm is offline   Reply With Quote
Old 12-22-2015, 12:29 PM   #2
Jhochst's Avatar
I have a Rockwood 1905. It's sister brand to flagstaff 19. Mine weighs around 3200 pounds. I pull with V8 Dodge Durango.
Jhochst is offline   Reply With Quote
Old 12-22-2015, 02:01 PM   #3
Mine is a 21 foot double axle.
Old 12-22-2015, 03:18 PM   #4
Happy Campers
Denny and Suni's Avatar
Talking Missing half a TT
Ours is a 2014 21FBRS with a dry weight of 3789. Where the wheels or something missing on yours. Over 200lbs. difference.
"I went to the woods because I wished to live deliberately...and not, when I came to die, to discover that I had not lived." H. D. Thoreau
2012 Nissan Frontier 4X4 Crew Cab Longbed
2014 Flagstaff 21FBRS
Some Yorkies
Denny and Suni is offline   Reply With Quote
Old 12-22-2015, 03:22 PM   #5
Happy Campers
21fbrs dry weight
We pull with Nissan Frontier V6 longbed 4x4. Factory added power awning and oven. We added second battery. Loaded the scales read 4000lbs.
Some Yorkies
Old 12-22-2015, 05:43 PM   #6
My luck, the floor supports are probably missing.
Old 12-22-2015, 06:09 PM   #7
Ours is a 2015 with a dry weight of 3821
2017 2500 Silverado gas, 2015 rockwood 2109s
ddrockwood is offline   Reply With Quote
Old 12-22-2015, 06:29 PM   #8
How do you like the air bags. I use an equalizer weight distribution hitch. I recently put a topper on mine and the rear is sagging a little now. I'm either gonna put a new leaf spring set or the air bags on it.
Old 12-22-2015, 06:49 PM   #9
I like them. I tow different trailers so I need different air settings.
Old 12-22-2015, 07:13 PM   #10
Maybe the guy typing the numbers on the sticker had fat fingers.
2011 Traverse LT, 3.6L, FWD
Old 12-22-2015, 07:30 PM   #11
JohnF's Avatar
3714 for me
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 12-22-2015, 07:31 PM   #12
TURBS's Avatar
Lower dry weight means higher ccc no?
Is your ccc the same as higher dry weight counterparts?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 12-22-2015, 07:36 PM   #13
Happy Campers
Dry weight
We just got a quote on a topper. Hope we don't have to use airlifts!
Where are you from? Just get trailer in May?
Some Yorkies
Old 12-22-2015, 11:21 PM   #14
I'm in northwest fl. We camp at st andrews state park in panama city alot. We got our trailer in May too. I put a derale 52506 transmission cooler to replace the tiny one that came on my tacoma. I also have a scanguage to monitor transmission temps. I will be putting the firestone air suspension on my Tacoma. That way I don't have to use my distribution hitch which weighs 100 lbs by itself and makes one hell of a racket. We live in the woods.
Old 12-23-2015, 02:04 AM   #15
Just make sure you run a sway control. Ours had some sway to it. With the sway on it towed very good. I would not tow without it.
Old 12-23-2015, 12:54 PM   #16
Lost Vermonters's Avatar
Mine is a 2015 and about 3700 pounds
After 17 years gone - Finally moved back to Vermont 2016.
2015 Microlite 21 FBRS
Silverado 1500 TV
Lost Vermonters is offline   Reply With Quote
Old 12-23-2015, 01:28 PM   #17
dmchapman's Avatar
2015 Flagstaff 21DS. I guess the lightweight frame is the limiting factor on cargo capacity. Dry weight 3975 weight of cargo not to exceed 855 lbs
dmchapman is offline   Reply With Quote
Old 12-23-2015, 02:45 PM   #18
RVPP's Avatar
We have a '04 Surveyor and the sticker says 3750.
RVPP is offline   Reply With Quote
Old 12-23-2015, 04:27 PM   #19
BillyBass's Avatar
i have a 2012 FBRS and my dry weight is 3745
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
Old 01-07-2016, 03:52 PM   #20
Old Bill's Avatar
I have a 2014 model and the dry weight is 3801.
Bill & Lynne
2017 Cougar X-lite 25RES
2017 F150 SCrew, 2WD, HDPP, MaxTow, 3.5 EcoBoost, 6.5' Bed
Anderson Ultimate Fifth-Wheel hitch
Old Bill is offline   Reply With Quote
weight
