Nothing like a Hurricane ("Nate") to help you find roof leaks.
The storm came through this morning. Not a lot of heavy wind but was a lot of rain.
I had a small chore in the trailer this afternoon. I turned the battery switch on and turned on the interior lights. 5 minutes after entering the trailer I heard a weird noise that I traced to the speakers.
Pushed on the rear speaker housing and water drained (not dripped) out.
I removed the rear speaker and was able to reach in and unplug the wet stereo system. There appears to be a leak either at the radio antenna or solar plug (I don't have a solar system at this time.). The roof sealant looked intact.
I dried the area around and used about 1/2 of a roll of duct tape over both the top and sides of both openings.
Water damage is not significant on the cabin. However, most likely the stereo is toast.
Since purchase this will be the 2nd time back to the dealer. (Crimped gas line to stove.)
BTW, there doesn't appear to be an easy way into the radio cabinet.
I am depressed and disappointed.
