Hi,
We have owned our E-Pro 19FD trailer for a year and a half. I have never dropped the spare tire from under the trailer or had to deal with a tire change. (I've kind of dreaded the thought having to do it.)
We went out last week and had a nice camping trip, until I noticed tire was flat as we were getting ready to leave. The jacks/stabilizers hid the problem until the last minute.
Now, I had to change the tire!
I lowered the tire from underneath the trailer. This was a "royal pain" due to the
location of the tire under the trailer behind the steps. It uses a pulley system to raise and lower it. You have to physically get under the trailer to unhook the tire.
I tried to loosen the wheels lug nuts. They had been over-torqued at the factory and initially were almost impossible to break loose.
Otherwise, jacking the trailer and replacing tire was not that difficult.
After getting home, I checked the tire and found no leaks except at the tire stem.
The tire stem was loose. This caused the air leak.
I tightened the stem 4-5 turns to seat it and leak stopped.
Note: I've added air to the tires several times since we owned the trailer and have not had any significant leakage problems. After finding this, I checked the other tires and the stems were
properly seated. I believe that this issue originated at the factory.
After mounting the original tire back on the wheel, I tried to pull the spare back into position. It was extremely difficult to do this as it took a lot of effort/muscle to slowly hoist it back into position.
Overall, I felt that this was more difficult that it needed to be.
I suggest:
- Check your tire stems (cores?) and make certain they are tight.
- Make sure to loosen and re-torque your lug nuts before you take it out the first time.
- Have a good jack available (in this case I did).
- Know how to access your spare tire the E-Pro/Geo Pro trailers.
Let me know if it is difficult to raise your spare as I may have defective pulley system. I would interested to know if anyone else has had to change a tire on this type of trailer. What was your experience like?
