Old 10-18-2018, 01:31 PM   #1
E19FD Winterizing
In the water line from the Fresh Water tank is a valve with a connection for adding a hose to draw Antifreeze into the plumbing. I have tried using it after blowing the water lines out with air but the Pump will not draw antifreeze with the valve in any position. Has anyone had any luck using this connection?
YBLee is offline   Reply With Quote
Old 10-18-2018, 01:57 PM   #2
007matman's Avatar
If it's like mine, the valve has several positions. Try turning that while the motor is running. You'll hear it when it's pulling in air. Then just submerge the end in the antifreeze.
007matman is online now   Reply With Quote
Old 10-19-2018, 02:19 AM   #3
Thanks a lot for the feedback. I did try that but now I'm thinking the Valve was installed backwards. I'll try reversing it tomorrow and see is that works.
Old 10-19-2018, 06:35 AM   #4
Trailer Park Supervisor
NJKris's Avatar
OMG, can you have any more problems with that trailer????????
NJKris is offline   Reply With Quote
Old 10-19-2018, 10:55 AM   #5
Winterizing Issue
I sincerely hope not. Luckily I was able to blow all the lines out with my compressor and empty hot water heater, etc. While doing this process I removed the Whole-House style Water Filter in the compartment on the back left side of the E19FD to empty the water. Low and behold I found the there "was not" an actual filter membrane in the housing - LOL! This is really comical after awhile. I'm going to keep plugging away at all the issues and make this the camper it should be! We camped in NH last weekend and had a great time and basically love the camper except for all the issue including the Aluminum Framing of the camper itself, the use of Azdel instead of Luan in the walls and what seemed lake a lot of extra features that more expensive units had that were included like the RangerWifi. BUT, there's more than a good deal/price and I've learned a lot. You probably won't want to be the next dealer I purchase from unless you've done your homework and insure the camper I'm buying is perfect!
Old 10-19-2018, 02:28 PM   #6
NJKris's Avatar
I'm learning from your experiences and know what to expect at least. Almost 18k for this is not a lot in the big scheme of things, but is still 18k I wouldn't have spent otherwise. I know they don't deliver the trailer with a filter element installed, but they should have given it to you. If not, they owe you one.
Old 10-19-2018, 02:45 PM   #7
I've not seen a new unit from the factory with the filter element installed in the housing.
That's typically the job of the dealer during PDI and often times the dealer will wait until the Customer Orientation to show the owner how it's installed. Depending on how good/bad a dealer you have, they may just point it out to you (laying in a drawer or cabinet) and say "that goes in the filter housing!"
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 10-19-2018, 08:23 PM   #8
Well, they didn’t do that I’m sorry to say. After replacing an I correctly installed Inline Winterizing Valve near the Fresh Water Tank, it still would not draw Antifreeze so I gave up and pored the antifreeze into the Fresh water tank and pumped it through the system with the pump. Done but not happy!
Old 10-20-2018, 06:45 AM   #9
NJKris's Avatar
This winterizing stuff is new to me. If you blow the lines, then try to start the pump, the pump won't be able to prime and provide suction and draw it in the way you wanted I'm thinking. Could it be that simple? Now that there is liquid in the lines and pump, maybe try the process again and see if is sucking in?
Old 10-20-2018, 07:56 AM   #10
That is a good point (and I will try it next year) but then why would it draw the antifreeze from the fresh water tank with dry lines? I even cracked the kitchen facet to all air out so the lines wouldn't be "air-bound". At this point it defies logic but is winterized.
Also, there is a Check-Valve behind a little screen in the City Water hookup that should be pressed to allow antifreeze to get into the check-valve. You can gently pick out the Screen with your finger which has is attached to a black washer. Then stick your finger in the hole and you'll feel kinda like a button. ***CAUTION CAUTION*** Before you push that check-valve button, make sure the Water Pump is off and some of the pressure is relieved by open one of the facets OR YOU WILL GET REALLY WET WITH ANTIFREEZE. I speak from experience - lol.
winter
