Hello
Second year out on our Microlite 25 DS. We have the retractable electric awning and pondering if we should have tie downs or something for strong winds. What is the consensus on this? Also any good cleaning suggestions on the awning?
Also, I am just curious, what prevents this awning system from detaching from the travel trailer or rolling down while traveling? Is there some type of locking system automatically engaged? Just curious...fairly new to this.
Hello
Personally, I think tie downs are needed if you'd like to be able to leave the awning out without worry. I use OC's awning tie down poles every trip.
Also any good cleaning suggestions on the awning? Spray with decent cleaner, and roll up for 20-30 minutes. Unroll, scrub the really bad areas and rinse.
Also, I am just curious, what prevents this awning system from detaching from the travel trailer or rolling down while traveling? Is there some type of locking system automatically engaged? Just curious...fairly new to this. I believe just the motor itself, and tension spring, holds the awning in.
Thanks all!
Happy Campin!!
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
Hello
Thanks all!
Start following posts by Turbs and OldCoot for the awning scoop. These gents seem to be on top of this.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
WOW! This one kind of went off topic quickly. The site team did a cleanup here and removed several postings..... and for the sake of forum harmony, let's not try to rehash it here or anywhere else on the forums.
Thank You
2011 Flagstaff 831 RLBSS
