Originally Posted by OswegoLion
Mine is digital. It doesn't turn off if I set lower temperature.
How do you set the temp?.....on the fireplace control panel itself or on a remote for the fireplace?
We had a digital remote in our stick & brick house and the remote was the thermostat. If I set the temp. then put the remote away in a closed cabinet, the heat would not turn off because it stayed cooler in the closed cabinet.
I had to leave the remote out in the open air of the room for it to sense the air temp. to turn off & on.
2014 Prime Time Sanibel 3250
