Originally Posted by Regthehabsfan
Thanks for all the input. We(my wife and google) found the resets on the switches. It seems that everything is working find.
Could you possibly be referring to the resets on 12v circuit breakers?
I've not seen resets on switches.
Did the thing(s) you reset look like this?
If so, they are reset style circuit breakers designed to give the circuit protection similar to a fuse but with the ability to be reset and reused.
On my 5th wheel these circuit breakers are located in the front storage near the battery and the battery disconnect switch. I have several and they are NOT connected through the disconnect.
