Old 07-28-2017, 10:19 AM   #1
Electric Panel
I have a 2014 Flgstaff Classc Super Lite 34 ft. with 3 slides. Unfortunately I do not currently have the luxury of utilizing enough. I hooked up my truck to open the unit at storage and only the closeouts worked. I have no lights or awning power. all the fuses and breasts look good. Any help is appreciated.
tcolter is offline   Reply With Quote
Old 07-28-2017, 10:25 AM   #2
PPST Wannabe
kenandterry's Avatar
I suspect your 12v battery(s) are very weak. Are you sure you turned off the battery disconnect switch? Did you turn it back on when you opened the rig?
It would be best if you had a volt meter for a reading of the batteries as you indicate you store it off site. If you can, get it to somewhere you have access to electricity and have the unit charge up for at least 24 hours, then see if things work better.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-28-2017, 10:26 AM   #3
PPST Wannabe
Breasts might look good.....but breakers is what you need to check.
Ken and Terry
Old 07-28-2017, 10:28 AM   #4
Do you have a battery in your unit?
Sounds like your battery cut-off switch might be off.
Many times the slides are wired to work directly from the battery. (or in your case, getting 12v from the truck, or shore power/converter if connected)
But with the battery cut-off turned off, you'd have no interior lights or awning as the 12v source (truck/converter) wouldn't be getting to the inside of your camper.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-28-2017, 10:33 AM   #5
There are so many things I can say to this. If you're gonna have an autocorrect fail this would be the one to have.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
electric
