Old 09-17-2018, 12:19 PM   #1
electric rear stabilizer
set up camp and went to lower elec rear stabilizer on my 2014 F/R Flagstaff - would not go down so I got crank handle and manually set it down- hit button to retract and it works fine, hit button to extend and nothing-- whats the fix??
DeeWayne is offline   Reply With Quote
Old 09-17-2018, 12:30 PM   #2
First guess would be bad switch for dwn position not making contact.
TheWolfPaq82 is offline   Reply With Quote
Old 09-17-2018, 01:39 PM   #3
Have you checked power at the switch?
That's a DPDT rocker. It could work in one direction but not the other.
Do you own a multimeter and know how to use it?
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 09-17-2018, 02:36 PM   #4
stabilizer
Thanks- gives me two areas to check..
Old 09-17-2018, 05:56 PM   #5
Wayne Joan's Avatar
New switch. It is a mini breaker and has probably been tripped too many times.
I had to replace mine. Works fine now.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
98 days camping 2018
85 days camping 2019
Wayne Joan is offline   Reply With Quote
electric
