Old 08-19-2019, 07:21 PM   #1
Electrical
I am looking for a electrical diagram for my 2008 Flagstaff classic super lite 8524rkss. Seems like my refrigerator, 12v lights, and water pump won't work when I run off battery. Anyone know what the problem might be?
sweetiepeetie is offline   Reply With Quote
Old 08-19-2019, 07:40 PM   #2
Flybob's Avatar
Check resettable breaker under frame near hitch.
Check to insure the battery disconnect switch is on.
Check to two high current ( 30-40A) fuses in the distribution panel.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-20-2019, 07:56 AM   #3
Wiring diagrams are almost non-existent, especially older units.
As Flybob mentioned, sounds like you have a tripped 12v circuit breaker or corroded connections at one of them. I've seen photos where the attaching lugs were almost completely rusted away.
If you have a multimeter and know how to use it, you can trace the wiring from the battery to the converter and through to each 12v circuit.
Best of luck and let us know what you find.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 08-20-2019, 09:15 AM   #4
Electrical
I forgot to mention I can run the slide out and the front jacks off of 12v so it isn't totally gone.
Old 08-20-2019, 09:25 AM   #5
Did you find the breaker described above? That is most likely your issue.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
CedarCreekWoody is online now   Reply With Quote
Old 08-20-2019, 09:25 AM   #6
Flybob's Avatar
These two items are usually connected directly to the battery via a fused cable so if the battery is good they will work.
TST Tire Monitors
2 100W solar panels
Old 08-20-2019, 09:26 AM   #7
SeaDog's Avatar
The slides and jacks may be wired direct to the battery with their own breaker, like others have said check the breakers and connections, check your batter disconnect.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-20-2019, 07:13 PM   #8
Electrical
The 30A fuse by the battery box upfront is good. I have continuity on the negative from battery to the circuit breaker/fuse compartment but not on the positive (red wire). Have not been able to find a inline circuit breaker or disconnect switch which I think must be the issue. Don't really know where to look for this.
Old 08-20-2019, 07:18 PM   #9
Flybob's Avatar
Did you push the small button on the side of the resettable breaker?
TST Tire Monitors
2 100W solar panels
Old 08-20-2019, 07:29 PM   #10
Just as confused as you
Scrapper's Avatar
Visually trace the positive cable from the battery inside your battery compartment you find the breaker/resetable fuse. Since you have a 5er you may have a different style than those in Flybob's photo.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-21-2019, 08:27 PM   #11
Smile Electrical
Good news. After hours of searching and troubleshooting, I finally found the culprit, Inside the front king pin assembly there is a little 40a circuit breaker. At first I thought it was just a terminal block but it actually is a little breaker and it was tripped. Pushed the little button in and everything worked just fine. Thanks for all of you for helping.
Old 08-21-2019, 11:08 PM   #12
bikendan's Avatar
Flybob wins! Post #2
Equalizer WDH
Old 08-22-2019, 09:22 AM   #13
Head Rambler
Thanks for coming back and letting us know that you found it and got your problem resolved.
Gotta go campin!
Old 08-22-2019, 01:26 PM   #14
Scrapper's Avatar
What, pray tell, does he win?
Richard & Jill
Old 08-22-2019, 02:13 PM   #15
bikendan's Avatar
Equalizer WDH
Old 08-22-2019, 02:26 PM   #16
An all expense paid trip of his choice to any R/V resort in the country... but wait... there is more... if he acts withing the next 3 minutes... he'll get two rolls of Flex Seal® AND a Popeil Ronco® Pocket Fisherman rod/reel combination.
(offer expires in 15 seconds)
electric, electrical
