Old 09-25-2014, 07:43 PM   #21
Slympicins's Avatar
Is it that cold there already? Glad we are in the CG capital of the nation cause we are going out again this weekend. Yahoo!!!
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 09-26-2014, 08:24 AM   #22
cat1956's Avatar
I would like to share an Electrical problem I had with my running lights on my 2014 27RLWS.
ID:	63564   Click image for larger version
ID:	63565   Click image for larger version
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 09-26-2014, 04:19 PM   #23
Larsone
Looks like your lucky it didn't start a fire.
What were the symptoms and signs or early warnings leading you to pulling out the wiring?
My external lighting seems to be okay for now but I would want to know if this is happening before the flames develope. I have a 2014, 27 RLWS also (white)
Gene
Larsone is offline   Reply With Quote
Old 09-26-2014, 04:21 PM   #24
I strongly suggest you have a qualified technician look at your problem. From the photos it looks as if you have a short in the wiring, which has the potential of causing
big problems. The wires need to be tested from the power source to the switch, then to each lamp.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
SparkeyBob is offline   Reply With Quote
Old 09-26-2014, 04:54 PM   #25
cat1956's Avatar
Gene
The running lights were very dim and those at the top were the dimmest so I started their and found it. I replace all the wires at the top.
Tommy and Wanda
electric, electrical
