Old 10-09-2014, 04:28 PM   #1
Exterior Cable TV/Satellite IN Connectors
Hoping someone from the Flagstaff factory monitors this forum!!
Have a 2014 Flagstaff 5th wheel and have a question that the dealer cannot answer. Between the CABLE TV F-connector and the SATELLITE IN F-connector on the rear/side of the trailer is a small female mini-jack. What is the purpose of this mini-jack? Here are the photos
ID:	64428   Click image for larger version
MartyQ is offline   Reply With Quote
Old 10-10-2014, 03:17 PM   #2
Maybe audio in from iPod, or audio player.
jwedell is offline   Reply With Quote
Old 10-10-2014, 09:41 PM   #3
That was what I thought but my unit had the "audio in" on the head unit inside the trailer. Besides you'd not want to have your electronics plugged in outside and on what would likely be the street side (non frequented / supervised) side of the trailer. So I discounted that theory.
Then I thought "audio out" for small outside speakers. But then on his 5th wheel he'd likely have outside speakers on the curb side under the awning so no need for speakers on the street side unless one wanted music while dumping.
It could be a jack for low voltage power, but to power what?
So this remains a mystery for me too. Were I the OP I would contact Customer Service and see if I could get a picture to them in support of the question.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 10-11-2014, 03:08 AM   #4
Your dealer should know, note I said Should. You may try to stop in a Best Buy as they have all the tech gadgets to find out what it is.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
SparkeyBob is offline   Reply With Quote
Old 10-11-2014, 06:14 AM   #5
Ford Idaho's Avatar
Have you pulled the plate and noted what type of wire is hooked up to the small input jack?
Old 10-11-2014, 06:32 AM   #6
There is writing behind the labels, can't make out what it says. That may be a clue.
On edit, never mind it doesn't help.
Old 10-13-2014, 02:08 PM   #7
I specifically asked this when I picked up our new camper this weekend. Dealer's tech said it was a screw hole for a cover plate on certain models of camper. Ours just don't have a cover plate.
ncbrit is offline   Reply With Quote
Old 10-14-2014, 09:43 AM   #8
Mystery solved. Yes, it is a threaded hole for a cover on some of the Flagstaff models. I received the following from the Flagstaff factory via e-mail.
"There is no jack in the middle of your cable satellite hookup…………that is actually a threaded hole for the cover that goes on the hookup."
Old 10-14-2014, 03:34 PM   #9
irt
My guess is maybe +12vdc aux power output
irt is offline   Reply With Quote
exterior, satellite
