Old 07-04-2014, 05:19 PM   #1
External TV Connection on 23LB
I have a Micro Lite 23LB, and trying to hook up the external TV. However, without cable at the site, I am using the powered antenna on the roof. I am not getting any signal when I try to connect the TV. Does anyone know what the outdoor connection is linked to? Does this connection only work with satellite or cable connection through the hook ups, or will it also connect with the powered antenna?
wdbrady is offline   Reply With Quote
Old 07-04-2014, 06:23 PM   #2
Slympicins's Avatar
Near the cable outlet there should be a power button for the antenna amplifier. Give a push an a light will come on. Retune the tv and you should be all set.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 07-04-2014, 10:53 PM   #3
Evereddie's Avatar
It should give you the same 'feed' that goes to your TV from the wall plate. If you have the little button pushed to power up the antenna it should show that. If the button is turned off it should give you the cable input if there is one.
Evereddie is offline   Reply With Quote
Old 07-06-2014, 05:23 PM   #4
Thank you all for the quick answers! Turns out I had a bad TV, and not sure it would have found a signal anywhere. :-)
New TV = Working Channels.
23lb
