Old 09-07-2016, 11:40 AM   #1
Devilscreekw's Avatar
EZ Slide and Seal Saver
I bought a can of each in 2014, and am starting to run out of both. Up here, the EZ Slide cost $26 and the Seal Saver was $18. Our dollar was pretty well at par at the time, and I am afraid to face the price now.
However, the EZ Slide smelled just like WD40 when I applied it, and the Seal Conditioner smelled just like Armorall.
Anyone know if I can substitute these cheaper generic products, or what is everybody using to lube slider gear and track mechanisms, and to preserve the slider gaskets and seals?
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 09-07-2016, 11:51 AM   #2
I use WD-40 'Specialist' Dry Lube with PTFE on the slide mechanisms.
I use 303 Rubber Seal Protectant on the seals or regular 303 Protectant if I'm out of the rubber seal stuff. (seems to be the same stuff??)
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
slide
