Old 04-28-2012, 09:21 AM   #1
Fan won't work.
Create a breeze fan in bath won't come on. Worked fine at home. Fuse looks good. Any ideas? Don't have a ladder to get on roof.
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 04-28-2012, 09:40 AM   #2
TURBS's Avatar
is the switch stuck at vent lid ?
Old 04-28-2012, 09:45 AM   #3
Don't have any way to get on roof to check and can't find any way to check from inside.
Old 04-28-2012, 09:59 AM   #4
TURBS's Avatar
the switch is on the inside .
just above the screen theres a switch that closes and shuts off fan when the cover comes down .
clear as mud ?
Old 04-28-2012, 10:16 AM   #5
clear as mud ?
Can't get the screen off. There is a place on the side where I can get my finger under the rim but I've pulled down till it felt like it might break and screen won't come off.
Old 04-28-2012, 10:44 AM   #6
TURBS's Avatar
Pics?
Old 04-28-2012, 10:45 AM   #7
TURBS's Avatar
IIll take a few of mine to show you in a bit
Old 04-28-2012, 10:57 AM   #8
Don't know if you can see much from these. The screen appears to be held in by small tabs around the rim. There is a small area recessed down that appears to be there to pull the screen down but I have pulled down and the screen just won't budge. Won't turn either direction either. Can live without the fan but would be nice come time to shower but do you have to shower when camping??
ID:	12906   Click image for larger version
ID:	12907   Click image for larger version
Old 04-28-2012, 11:03 AM   #9
Herk7769's Avatar
Lets start at the beginning.
The light switch on the wall MUST be on to run the fan.
Before I switched all the lights to LEDs I hated having to run the ceiling light when I wanted the fan to run. I rewired it to have its own switch.
The cleaning instructions attached have the screen removal instructions.
Name:	10 July 2011 050.jpg
HAM CALLSIGN - KC3FFW
Old 04-28-2012, 11:10 AM   #10
Thanks Herk. Didn't have the wall switch on but guess what. Turned on wall switch and fan fired right up. Thank heavens for this group. Just never tried fan after dark. Now going to scout out other campgrounds in area.
fan
