Old 03-13-2017, 05:55 AM   #1
OswegoLion's Avatar
Fireplace Help Please
Hi. Question about fireplace. Remote will not turn it on. I can manually turn on flame but not fan or heat. I will need it when I go north in late April. Any suggestions? Not even sure of company or troubleshooting.
OswegoLion is offline   Reply With Quote
Old 03-13-2017, 06:13 AM   #2
Georgia Rally Coordinator
aceinspp's Avatar
There is a main on/off switch and then a secondary one also if it's like mine. Both have to be on. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
aceinspp is online now   Reply With Quote
Old 03-13-2017, 06:14 AM   #3
wmtire's Avatar
First thing to check is the batteries in remote. If it's an infrared type remote, you can a lot of times use your cellphone camera to check.
Turn your camera on, and aim the remote at the camera, then push buttons. Looking at the camera screen, you can see the infrared light on the remote coming on if the remote (and batteries) are good.
Not all phone cameras pick this up but many do.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 03-13-2017, 06:31 AM   #4
If it is like mine, it has to be really close to the fireplace and at the same height of the fireplace.
2017 Wildcat 327RE
2005 Chevy Silverado
2016 Nights camped in wildcat(14) didn't count previous trailer
2017 Nights camped (44)
2018 Nights camped (29) that's too low. Must work on it.
maskins is offline   Reply With Quote
Old 03-13-2017, 06:39 AM   #5
BamaBob's Avatar
In almost every case it is probably a Graystone Fireplace. Take a look at this site and see if any of these models look like yours:
Featured Products
Once you know the model number, you can then search for a PDF of the manual via Google.
Most fireplaces duplicate remote control buttons on the fireplace panel - odd that you cannot adjust heat & timer. Also, I suspect you are not adjusting the "fan" per se but the thermostat temperature (which controls how fast the fan rotates).
How new is your Fireplace? If it is still under warranty, call Flagstaff and see what their warranty folks can do for you.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-13-2017, 06:41 AM   #6
Mine did not work either. There's a phone number on the back of the remote. Call them and they'll send you a new one. They're in Indiana.
MartyNH is offline   Reply With Quote
Old 04-07-2017, 03:44 PM   #7
Yep. Same thing. When I got my 5er 3 years ago the remote didn't work. Called the dealer and they had the vendor send me another. Worked fine ever since.
Ken
TooLoose - WeTrek
04.5 CTD 2500 Dodge 6spd manual
2014 Flagstaff 8528ckws
elkabong is offline   Reply With Quote
