Old 06-20-2017, 01:07 PM   #1
Teksyn's Avatar
First minor issue with new/used Trailer
This morning I decided to do another PDI prior to our upcoming first trip. Everything worked as expected, except for the vent-a-hood fan over the stove. I'm almost positive that I checked it before taking possession. I bought from an individual, so I will be fixing it myself. The light works, but the fan will not run. I am hoping that it is something simple. Could it be a fuse or just a loose connection somewhere? I did pull the filter and theban will spin freely. I ran out of time before work, so I couldn't trouble shoot further. Any advice from more experienced rv'ers, or someone who has had a similar issue would be appreciated. Thanks in advance.
An armed man will defeat an unarmed man with monotonous regularity.
2015 Flagstaff 27rlws Emerald Package
2013 F-150 5.0 Platinum Screw 4x4
Teksyn is offline   Reply With Quote
Old 06-20-2017, 01:12 PM   #2
llr
I doubt if they ran separate power for the fan and light so I would start with the fan switch and fan
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 06-20-2017, 01:16 PM   #3
Teksyn's Avatar
Thanks, I was thinking that way also.
Old 06-21-2017, 08:49 AM   #4
Those little fan motors are susceptible to the brushes sticking. Especially when not used much, such as the range hood.
Turn it on and give it a spin with your finger (be careful) and see if it might start running.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 06-21-2017, 12:45 PM   #5
Just guessing and I'm hoping someone else will correct me on this ~ Is there any chance that there might be a micro switch to keep the fan from energizing if the outside vent is closed/latched?
extxn is offline   Reply With Quote
Old 06-21-2017, 01:26 PM   #6
I have never seen one on an R/V.
Old 06-22-2017, 01:27 PM   #7
There is a thermal link in the positive lead from the switch to the fan that went bad on my Rockwood. It's soldered in place.
Tim & Eileen
2016 Cedar Creek 34RL towed with a 2017 Silverado 3500HD Diesel
timerie is offline   Reply With Quote
Old 06-23-2017, 01:29 AM   #8
Teksyn's Avatar
The outside vent was opened. I thought of this also and checked, but did not find anything. Working nights now, so I will trouble shoot more on next off day and will report the solution if found.
Old 07-08-2017, 10:16 PM   #9
jshenry's Avatar
I had this same issue with the fan not working. It was the thermal link. I removed the link and put an in line fuse in it's place. Now all works as new.
jshenry is offline   Reply With Quote
Old 07-09-2017, 12:09 AM   #10
Teksyn's Avatar
Thanks, I'll look for that. What size fuse did you use to replace the thermal link?
Old 07-15-2017, 05:58 PM   #11
jshenry's Avatar
10 amp blade type. Same amp as the part I cut out. Cost was a couple of dollars
trailer
