Old 01-13-2016, 07:18 AM   #1
Unhappy Flagstaff 21 FBRS water heater question
How does one access the rear of the water heater on a 21fbrs?
bayoudonnie is offline   Reply With Quote
Old 01-13-2016, 07:32 AM   #2
TURBS's Avatar
Hot water heater won't work
Behind a false door or behind a drawer inside camper.
Look where it is on the outside then imagine on the inside where it would be then figure out what it's behind or in
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-13-2016, 07:21 PM   #3
I have the little counter top on the right as soon as you walk in the door, take out the end draws by releasing the slides... little black tabs on the tracks, pull out and look straight back at the heater and you will see the valves. if you already have water at the faucets turn the one in the center so it faces across the pipe not inline. turn on sink hot water valve and the should do it.. just slide the drawer back in all the way it will reset good luck with your trailer
rayo11 is offline   Reply With Quote
Old 01-19-2016, 07:33 AM   #4
15 -21FBRS 17-F150 2.7 e
J.Fallon's Avatar
Left side forward compartment outside of trailer. Open door, remove 2 screws (square drive) on Panel to your right or rear of trailer. You will expose the water heater. Remove screw on panel to your left or forward and you will expose water pump and water filter.
2015 21fbrs
2014 Ford F-150 4x4 5.0
J.Fallon is offline   Reply With Quote
Old 01-25-2016, 08:32 PM   #5
Life Without Whine's Avatar
for what it is worth ....put a c-clamp on your outside entry door to the water heater....ours went sightseeing without us (left us on I-75 somewhere) so we just had to order a new one ....
Terri + Joe + BrewDog Boont
Camping a long weekend every month since starting in May of 2013 in order to practice for retirement .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
Old 02-05-2016, 07:35 PM   #6
Correct answer
Correct answer.
2015 21fbrs
danking49 is offline   Reply With Quote
water heater, flagstaff, water, heater
