Old 04-20-2018, 07:15 PM   #1
Flagstaff 23LB Water Leak
I posted the below in the Rockwood forum
Itís behind the hotwater tank and I canít see it. If I look under the camper towards the very back corner, to the right of the hot water heater if facing it. Underneath that area is leaking.
I took the wood divider off in that back outside compartment but canít see the leak because its on the other side of the hot water tank.
I actually have a Flagstaff 23LB which is the sister to the 2306. I will post in that forum also but the 2306 is more popular so I started here.
I did turn off the city water.[/QUOTE]
2018 Flagstaff Micro Lite 23LB
Equalizer 4 PT. WDH 1k/10k
2012 Jeep Grand Cherokee V8 4x4
jk70 is offline   Reply With Quote
23lb, flagstaff, leak, water, water leak
