Old 03-10-2014, 08:42 PM   #11
asquared's Avatar
Is it sway or wiggle? Sway is defined as the rear end of the trailer oscillating side to side with increasing speed and distance of oscillation. Is the rear end doing it or the whole unit moving as one? Or are you having more of a porpoising movement front to back?
More info is needed... what is tv (yr, make, model engine, rear end and 4wd/2wd), what hitch do you have (what is wdh rated for, any sway bars or is it an integrated hitch like Reese dual cam, equal-i-zer etc)? Have you been to the scales to weigh anything? This is very telling. What tires on TV (P rated, E rated) and what pressure are tv and tt tires running at?
Sway can be from too light of a tongue weight and too heavy on the rear end (I have moved a tent that weighs less than 20lbs from the back to the front and made a big difference in handling before). Too soft a tire on the tv (ie p rated tire or under inflated E rated tire) can have a negative impact on towing. WDH not adjusted properly can negatively impact as well... not enough weight transfer or too much transfer are both bad (you can tell by measuring height but also a more accurate method involves weighing at a cat scale). Not enough tow vehicle (especially with a short wheel base) can be bad too.... how do I know that? Been there done that with my old armada my friend.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-10-2014, 08:56 PM   #12
TURBS's Avatar
would be nice if the the op would come back and comment.........
Old 03-10-2014, 09:14 PM   #13
bikendan's Avatar
yep, the OP may not even be using a WDH with sway control.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-10-2014, 09:26 PM   #14
mark0224's Avatar
Under inflated tires on both tv and tt can also play into sway. Trailer and truck need to be one continuous level surface. Put a level on the truck and then on the tongue and compare the bubble should be the same. If they are not weight distribution and or the ball of your hitch are out of whack. Once you have adjusted and cked these try it again. If you haven't already look into sway control you probably should have some.
mark0224 is offline   Reply With Quote
Old 03-10-2014, 10:43 PM   #15
Looks like the problem is not serious enough for the OP to follow up.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 03-11-2014, 08:10 AM   #16
Fulltime family RVer
Ha! Relax fellas- lots of people can only check the forum once per day or so. Give 'em time.
Old 03-20-2014, 10:44 PM   #17
MoeBelly's Avatar
I just drove our new V-Lite 30WFKSS (same as OPs) from Fairmont, WV to Pittsburgh going 60-70 mph on the interstate. We have the Equal-i-zer WDH and tow with a Sierra 2500HD LB Crewcab. No noticeable sway and towed terrific.Click image for larger version
Name:	ImageUploadedByForest River Forums1395373481.841141.jpg
MoeBelly is offline   Reply With Quote
Old 03-20-2014, 10:57 PM   #18
Originally Posted by porter lizard View Post
I just bought a flagstaff 30 WFKSS and I picked it up and on my way home I could not get over 60 miles per hour with out it swaying to the extent that it was dangerous going on a curved overpass. I have a friend that just bought the same one and it does the same thing. we both are afraid to take them on a trip. what could be the problem?? I'm ready to take it back.
He did post this a day later:
New tow vehicle
Strange...
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 03-23-2014, 07:47 AM   #19
Wanna Be Camper
SaskCampers's Avatar
his last online date was the 17th of this month so I am pretty sure he has read all these posts. Another option for the OP to consider is the Blue Ox hitch. We use one on our V-Lite and when you get the rotary snap up brackets it is a breeze on a V nose trailer to hookup, almost like Blue Ox was thinking of the V nose crowd when they designed them.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-25-2014, 10:07 PM   #20
What are your weights (truck, trailer and tongue weight)?
flagstaff, towing, v-lite
