Old 03-10-2014, 05:22 PM   #1
Flagstaff 30wfkss v-lite most unstable towing
We bought a 2014 V-lite. We pulled it home and couldn't get it over 60 mph without it swaying all over the highway. It was very scary! I bought a Anderson sway control hitch. Pulled it to the Lake and it swayed the same way. It would actually push us off the highway. I pulled it with a duramax 2500 Diesel truck. Very disappointed in it. Does anyone have a clue to what is wrong.
porter lizard is offline   Reply With Quote
Old 03-10-2014, 05:25 PM   #2
Ford Idaho's Avatar
What are the two of you towing with and what type of hitch are you using?
Old 03-10-2014, 05:26 PM   #3
do you have sway bars attached?
primetime1 is offline   Reply With Quote
Old 03-10-2014, 05:27 PM   #4
Fulltime family RVer
From reading here on FRF - sway is induced by 2 things.
1) but enough tongue weight. You need 10-15% of the trailer's total weight as tongue weight. The only way to know is to weight your setup.
2) If your truck tires are "P"assenger tires, you will do well to upgrade to LT tires for stiffer sidewalls.
ependydad is online now   Reply With Quote
Old 03-10-2014, 05:28 PM   #5
TURBS's Avatar
P rated tires on tv?
TURBS
Sabre owners united!
Old 03-10-2014, 05:32 PM   #6
Dennis and Julie's Avatar
We also have a 30wfkss, we use a 1000lb round bar weight distribution hitch with left and right sway control bars. I tow with a 06 Chevy Silverado 1500 short box and since we added the left sway control it has been smooth sailing. Normally run about 60 to 65 mph.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 03-10-2014, 05:36 PM   #7
DDC
DDC's Avatar
Hensley Mfg., Inc. - Trailer Sway Eliminated - Guaranteed
Trailer Sway Elimination | Sway Control | Truck RV Trailer Hitch Accessories | ProPride, Inc.
Check out these, no need to control sway when there is none. I've used the Hensley for years on different trailers there not cheap but safety never is.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 03-10-2014, 07:47 PM   #8
Slympicins's Avatar
Check the alignment of the trailer axle as well. Had a small utility trailer that had a slight cant in the axle. With higher speeds, it was all over the road. There would be evidence of this with weird tire wear patterns.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 03-10-2014, 07:52 PM   #9
Engineer of Crazy Train
ChooChooMan74's Avatar
No sure if these will work on a V nose. Looks like the 30 WFKSS is a V nose.
What WDH are you using? Sounds like most people with A V nose is using a Equal-i-zer 4 point with good success.
Knowing what you're towing with would be helpful.
Looks like the fictitious dry weights are...
7038lbs, 882 on the tongue. Sounds well more than 10%
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-10-2014, 08:10 PM   #10
caper's Avatar
I tow a 3001w with Husky round bar and 2 friction sway bars. I found that the TT would sway when only using 1. Also the type of tires you have on the TV will make a difference. If you have "P" tires they will flex and cause sway.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-10-2014, 08:42 PM   #11
asquared's Avatar
Is it sway or wiggle? Sway is defined as the rear end of the trailer oscillating side to side with increasing speed and distance of oscillation. Is the rear end doing it or the whole unit moving as one? Or are you having more of a porpoising movement front to back?
More info is needed... what is tv (yr, make, model engine, rear end and 4wd/2wd), what hitch do you have (what is wdh rated for, any sway bars or is it an integrated hitch like Reese dual cam, equal-i-zer etc)? Have you been to the scales to weigh anything? This is very telling. What tires on TV (P rated, E rated) and what pressure are tv and tt tires running at?
Sway can be from too light of a tongue weight and too heavy on the rear end (I have moved a tent that weighs less than 20lbs from the back to the front and made a big difference in handling before). Too soft a tire on the tv (ie p rated tire or under inflated E rated tire) can have a negative impact on towing. WDH not adjusted properly can negatively impact as well... not enough weight transfer or too much transfer are both bad (you can tell by measuring height but also a more accurate method involves weighing at a cat scale). Not enough tow vehicle (especially with a short wheel base) can be bad too.... how do I know that? Been there done that with my old armada my friend.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-10-2014, 08:56 PM   #12
TURBS's Avatar
would be nice if the the op would come back and comment.........
Old 03-10-2014, 09:14 PM   #13
bikendan's Avatar
yep, the OP may not even be using a WDH with sway control.
Equalizer WDH
Old 03-10-2014, 09:26 PM   #14
mark0224's Avatar
Under inflated tires on both tv and tt can also play into sway. Trailer and truck need to be one continuous level surface. Put a level on the truck and then on the tongue and compare the bubble should be the same. If they are not weight distribution and or the ball of your hitch are out of whack. Once you have adjusted and cked these try it again. If you haven't already look into sway control you probably should have some.
mark0224 is offline   Reply With Quote
Old 03-10-2014, 10:43 PM   #15
Looks like the problem is not serious enough for the OP to follow up.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 03-11-2014, 08:10 AM   #16
Ha! Relax fellas- lots of people can only check the forum once per day or so. Give 'em time.
Old 03-20-2014, 10:44 PM   #17
MoeBelly's Avatar
I just drove our new V-Lite 30WFKSS (same as OPs) from Fairmont, WV to Pittsburgh going 60-70 mph on the interstate. We have the Equal-i-zer WDH and tow with a Sierra 2500HD LB Crewcab. No noticeable sway and towed terrific.Click image for larger version
Name:	ImageUploadedByForest River Forums1395373481.841141.jpg
MoeBelly is offline   Reply With Quote
Old 03-20-2014, 10:57 PM   #18
Originally Posted by porter lizard View Post
I just bought a flagstaff 30 WFKSS and I picked it up and on my way home I could not get over 60 miles per hour with out it swaying to the extent that it was dangerous going on a curved overpass. I have a friend that just bought the same one and it does the same thing. we both are afraid to take them on a trip. what could be the problem?? I'm ready to take it back.
He did post this a day later:
New tow vehicle
Strange...
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 03-23-2014, 07:47 AM   #19
Wanna Be Camper
SaskCampers's Avatar
his last online date was the 17th of this month so I am pretty sure he has read all these posts. Another option for the OP to consider is the Blue Ox hitch. We use one on our V-Lite and when you get the rotary snap up brackets it is a breeze on a V nose trailer to hookup, almost like Blue Ox was thinking of the V nose crowd when they designed them.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 04-25-2014, 10:07 PM   #20
What are your weights (truck, trailer and tongue weight)?
flagstaff, towing, v-lite
