Old 07-14-2013, 08:54 AM   #1
Flagstaff 30wfkss Vlite leveling question
Hi All,
Just purchased a 30wfkss flagstaff Vlite. Awesome trailer, but had a quick question for any one that owns this model or similar. When I am on a level surface and the trailer is level and then open both my slide outs, the trailer gets alot of lean towards the slide out side due to the slides being very heavy. Any tips on how to easily level this rig after the slide outs are extended? I have the power stabilizing jacks, but they don't do much for leveling.
Thanks in advance
sammyt74dp is offline   Reply With Quote
Old 07-14-2013, 09:19 AM   #2
Rugged Brown's Avatar
If I park on soft ground, like grass, mud, etc I usually level the trailer slightly higher on the slide side to allow for settling. If solid ground, I evenly level. I'm not sure of anything or any way to level side by side once you have the trailer set up with slides out. The stabilizing jacks should not be used for leveling or any major weight bearing for that matter.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 07-14-2013, 09:20 AM   #3
Wanna Be Camper
SaskCampers's Avatar
First a big
The stabilizers are for just that, to stabilize the trailer as the frames are so light putting any amount of pressure on them will cause issues with the frame. I have the same issue with our 30WRLS as it has 2 slides on one side and I just get it level then add an extra 2x10 under the slide side wheels and that is enough to bring the unit level when I put the slides out.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 07-14-2013, 09:48 AM   #4
Thanks for the replies. What I figure I will do on the maiden voyage is back the tires on to a leveling block (or 2) on the slide side to compensate for the sag and then add an adjustable slide out support underneath for stabilization.
Thanks Again!
Old 07-14-2013, 09:50 AM   #5
Alleged curmudgeon
Vern's Avatar
Originally Posted by TheSasks View Post
First a big
x2. We have the Windjammer 3008W (Rockwood equivalent to your rig) and use our Lynx levelers on the slide side (when setting up and before extending the slides) to make the slide side 1 1/2" to 2" high. When extended, the weight of the slides levels things out. THEN you extend the stabilizers to "stablize" (don't try to use them to level things as they and your frame are not designed to be so used).
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30)]
Vern is offline   Reply With Quote
Old 07-16-2013, 09:19 AM   #6
Dennis and Julie's Avatar
First a big
x2
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 07-16-2013, 10:22 AM   #7
Fulltime family RVer
Your owner's manual most likely recommends against using slide out supports. The theory (and one that I subscribe to) is that they can cause damage due to the camper moving around with the slide not moving with it.
ependydad is online now   Reply With Quote
Old 07-16-2013, 03:32 PM   #8
I always let my stabilizers down on the back slideout side first, then do the front side, then open the slide outs. Works for me!!! Randy
Old 08-05-2014, 12:27 PM   #9
I have a 30WFKSS as well as a friend of mine. The stabilizers will not keep the slide side of the trailer from being lower when the slides are out. He had his v-lite first and told me about the leveling issue on the slide side of the trailer. He always makes sure the slide side is elevated about 2" higher than the none slide side using blocks under the tires. This allows the trailer to be level. I do the same thing and my trailer is level.
Jsahj is offline   Reply With Quote
Old 08-05-2014, 01:03 PM   #10
Thanks Again!
Noooo ... no slideout supports!!! SaskCampers (and others) has the right approach since he now knows what added height is needed (over and above the ground being unlevel) to level the RV side-to-side due to the expected suspension sag caused by the slideout.
Slideout supports can cause a net upward force on the slideouts that could not be accounted for in the design. Then you'd have a different problem.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 08-05-2014, 01:46 PM   #11
I actually like the trailer to lean a little to the slide side so AC condensation drips off of that side away from where I am.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-05-2014, 08:54 PM   #12
Slympicins's Avatar
As for the lean, I just replaced my axles to fix the lean. The left side axles sagged about 1 1/4" which I thought was a little much. Now it's a tad higher than the right side but I'm sure over time, the extra weight on that slide will compensate well. I'm with WMoses, DON'T use anything to support (or lift) your slides. I think you would be asking for trouble with them...and get the trouble quick.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Slympicins is offline   Reply With Quote
