Old 10-19-2011, 10:46 AM   #1
wmtire's Avatar
Flagstaff 831RLBSS floor squeak
I started this thread as an answer to an older thread that had comments about the floor squeaking by the floor vent, near the rear door. I used some quotes from that thread, but can't update it because the thread is too old and won't accept new posts to it....hence this one. It may help others in the future.
Originally Posted by semlohde View Post
Next is the squeek that has developed at the vent area by the rocking chairs. I've had 3 places tell me it's normal.
Originally Posted by Rubbersidedown View Post
I realize that this is a little bit of an older thread, but thought I might chime in on the squeaking floor issue. We took ours back to the dealer and had them look at it. They told us it is actually the metal ductwork that is rubbing up against the frame or other stuff where it comes up out of the floor by the recliners. Between the dealer and myself we eventually got it "tamed down" but not completely eliminated. by cutting some of the excess metal off of the metal elbow section right below the vent and putting some rubber type tape between the metal parts and then retaping over the joint where they meet with the aluminum duct tape. Not perfect, but way better!
I had taken my trailer to the dealer a few weeks ago to install slide toppers and look at some warranty items. While it was there, I asked them to see if they could do anything about the squeaking floor....and according to the work order I received, it was the same problem as Rubbersidedowns. They said the ductwork was free-floating and rubbing the frame at that spot.
Here is what the order stated:
Floor squeaks by floor vent near rear door
Furnace duct was rubbing on framing. Stapled duct work to flooring so it wasn't free floating
Just letting others know in case they have the same problem as Rubbersidedown, Semlohyde, and myself.
2011 Flagstaff 831 RLBSS
Old 10-29-2011, 12:46 AM   #2
Floor Squeaks
Similar issue here, dealer repair order stated that the Suburban furnace "ducts to be rubbing against floor and lower structure causing squeaking noise. Removed register, lift ducts to prevent rubbing.."
Helped but not totally.
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 10-29-2011, 06:27 AM   #3
We had the same problem and they gave the same diagnosis, removed vent cover and attached duct work. It has been a year and still no squeak!
maconandk is offline   Reply With Quote
