Old 04-02-2016, 11:12 PM   #11
CZNEDY's Avatar
We had a pretty good rain storm today and I went out to check the window. The inside of the window is dry. The water is leaking out of the screws on the bottom of the frame. It is leaking out of three of six screws. Had to go to the car show today so I put a towels down on the counter and maybe I can take the window out tomorrow if it isn't raining.
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 04-03-2016, 09:25 AM   #12
Left Coast
That's also where/ how mine was leak'n....
Sent from my XT1080 using Tapatalk
Old 04-03-2016, 10:46 AM   #13
Maybe after traveling the screws loosen up. Ours is a 2014 and I have not seen any leaks. It is still covered up and looks like it will be for a while now, because we got 5" of snow and still snowing here in central New York.
edwrench is offline   Reply With Quote
Old 04-03-2016, 01:04 PM   #14
CZNEDY's Avatar
Hey Bib, where was the water getting in?
2018 BERKSHIRE 34QS
Old 04-03-2016, 01:38 PM   #15
CZNEDY's Avatar
Sorry, Bob
2018 BERKSHIRE 34QS
Old 04-03-2016, 03:36 PM   #16
Left Coast
Was gett'n around the bottom row of screws...pull the inner frame, and you'll see how the window is installed.... Where the inner meets the outerr, put a small bead of anti-leak (silicone) and reassemble frame to window
Old 04-11-2016, 05:06 PM   #17
CZNEDY's Avatar
So, you only had to take the inside frame off ,right. Or do I need to wait for a warm day and take the whole window out?
2018 BERKSHIRE 34QS
Old 04-11-2016, 05:16 PM   #18
Left Coast
Just take the inner frame off...then you'll see where to add silicone...outer frame edge is sharp, no lip, so where the inner butts up against the outer is where the water gets in
Old 04-16-2016, 05:27 PM   #19
CZNEDY's Avatar
I had to take the whole windy out and reveal it. There was water getting in from the outside. I remove the inner frame, then popped the window out. All of the foam sealant was off and wasn't completing the seal from the outside. I removed all of the old sealer and put butyl tape all around. Popped it back in and adjusted then tightened it down. We will check for leaks tonight with a flashlight after dark. Then tomorrow,with a hose.
2018 BERKSHIRE 34QS
Old 04-17-2016, 06:08 PM   #20
CZNEDY's Avatar
You can see where the corner seal from the factory failed. That's where the water got in.Click image for larger version
Name:	ImageUploadedByForest River Forums1460934478.535658.jpg
2018 BERKSHIRE 34QS
8528, flagstaff, leak, water, water leak
