Old 01-18-2018, 12:49 PM   #1
Flagstaff 8528rlikws axle questions
I have a 2016 Flagstaff 8528rlikws that has the dexter 4000 pound tandem axles under it. My first question is I want to replace all the bearings but cant seem to find the correct ones. Does anyone know what part numbers Ill need? Im hoping to have everything I need before I start taking it all apart.
Secondly I just purchased a 2018 Ram 3500 4X4 with the cummins as my new tow vehicle. I am also using a B&W hitch. With the hitch at its lowest point the 5er still sits nose high. I was thinking about purchasing one of the 2 and 7/8 inch lift for the trailer. Has anyone used one and what are your thoughts? Really appreciate the help.
bulldogs72 is offline   Reply With Quote
Old 01-18-2018, 01:09 PM   #2
If you have Dexter Torflex axles, here's a link to the service manual (600-8K axles) on Dexter's web site. It lists bearings, seals, magnets, etc.
Dexter has a lot of good information on their web site and are really good about phone calls too.
If you don't have Torflex axles, get your tag info off the axle and get in touch with them.
Dexter 600-8K Torflex Service Manual.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 01-18-2018, 01:13 PM   #3
I do have the torflex axles. I’ll check that out, thank you.
Old 01-18-2018, 01:31 PM   #4
BTW... 2 posts...
Welcome!
Old 01-18-2018, 03:02 PM   #5
Thank you, appreciate it.
Old 01-18-2018, 03:25 PM   #6
I contacted my local RV service place and they wanted 500 just to repack the bearings. Yikes. Ill tackle this one myself
Old 01-19-2018, 03:41 PM   #7
old40ford's Avatar
Welcome and don't worry, packing bearings is an easy job to do at home. Just keep everything clean and use the correct grease, don't over tighten the spindle nut.
Retired Auto body teacher/Retired RV Dealer GM
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
No Kids
No Pets
But lots of Fun traveling with my wife
old40ford is online now   Reply With Quote
Old 01-19-2018, 06:26 PM   #8
Dexter has great customer service. I have used email several times to contact them. I did have to crawl under the trailer and get the serial number off the back of the axle. It was not stamped very deep so I rubbed it with soapstone. Sent the number and got the build sheet bearing and seal info. Hub info and brake info.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 01-21-2018, 11:06 AM   #9
8528IKWS
We have a 2016 8528IKWS and tow with a Ram 2500. It sit nose high and when contacting Dexter about lift blocks for the Torflex axles, the rep told me it was not advised. My advice is to check with Dexter about the lift blocks
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
Old 01-21-2018, 01:57 PM   #10
Phat Steve's Avatar
Are you sure they are dexter axles. My Hemisphere came with 4400lbs lippert axles which are garbage and i cant even bring myself to resell them to someone. Lippert uses a 5200lbs axle tube and puts a 3500lbs spindle on it with a 6 lug 10in brake drum and calls it 4400lbs. Don't ask me how they get away with this when the bearings are for a 3500lbs axle. Needless to say I now have 2 6000lbs made in USA dexter axles.
Phat Steve is offline   Reply With Quote
8528, axle, flagstaff
