Old 11-24-2018, 02:52 PM   #1
Flagstaff Mini lite 21Fbrs
I’m looking at a 2019 Micro Mini Lite 21 FBRS, I’ve been in a couple but never paid attention to where the wall outlets are placed.
Primarily, is there an outlet in the slide out?
Traveling Circus is offline   Reply With Quote
Old 11-24-2018, 04:17 PM   #2
We used to have the same model. Ours did not have an outlet in the slide.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 11-25-2018, 08:35 AM   #3
In our 2017, as you look at the sofa there is an outlet on the left wall under the thermostat. It is covered by the slide when the slide is in.
DanMistyMiler is offline   Reply With Quote
Old 11-25-2018, 02:25 PM   #4
Thanks Dan, after going back and reviewing the online pictures, I believe I see the outlook that you mentioned.
Old 11-26-2018, 02:11 PM   #5
X2 correct!
Henboy is offline   Reply With Quote
Old 11-26-2018, 02:25 PM   #6
x3 Correct
gglray is offline   Reply With Quote
flagstaff, lite
