Old 04-01-2012, 11:37 AM   #11
Cool Dewinterizing
Originally Posted by Capsfloyd View Post
we have a 2012 flagstaff 831rkss ...been out for 2 days ,, fit finish very good
Hi just bought a new 23ft flagstaff and was wondering if you could help me walk throught the dewinterizing process, I have fivere valves and want to make sure I am doing the process right. Thanks
tuckster is offline   Reply With Quote
Old 04-02-2012, 05:06 PM   #12
Newbie
pg_rider's Avatar
Here's the de-winterizing checklist I put together for my Rockwood 2306 (same as the Flagstaff 23LB).
o Ensure water pump is connected to fresh water tank and not antifreeze inlet reconfigure valves if necessary
o Drain holding tanks (fresh water and sewage)
o Attach garden hose to fresh water fill and fill fresh water tank.
o Turn on pump switch and open cold water side of all faucet and shower fixtures
o Leave open until water runs clear, no pink
o Repeat for hot water side
o CHECK FOR LEAKS IN WATER PUMP AREA AND UNDER SINKS
o Flush toilet until clear water runs into bowl.
o Connect hose to city water connection and run all faucets, toilet, and showers.
o Dump tanks again.
o Turn hot water heater by-pass valve to open position to allow water to enter and fill the hot water heater tank
o Install new water filter.
o Check tire pressure 50 PSI
o Check lug nut torque 100 ft-lbs
o Inspect all vents for signs of bug nests
o Lube black and gray tank valve handles with Liquid Wrench silicone spray
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 04-02-2012, 06:20 PM   #13
Brigitte
boubou's Avatar
Drain holding tanks? I planned on dewinterizing at home, is that something that needs to be done at campsite?
Where would i drain holding tanks?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 04-02-2012, 06:38 PM   #14
TURBS's Avatar
you only need to drain tanks the last time you camp other than that your fine .
you can leave the antifreeze in them over winter
the amount of water in your tanks from de winterizing isn't enough to worry about till your first camping trip of the year .
