Old 04-07-2015, 02:45 PM   #11
Witch Doctor's Avatar
Originally Posted by SaskCampers View Post
Thanks! Instructions are always welcome, the bedroom slide only has one actuator and it is in the middle as it is a small slide the rear has 2 sets of adjusters.
Attached are the instruction, that looked like a big slide with the double rack. You probably have a good 1/2 " above. I had to cut the wall board because it hung a 1/4" below the metal opening. You can cut that with a box knife if you need to, You be surprised how easy it is to cut that inside wall. Remember to count your turns.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 04-07-2015, 02:51 PM   #12
If you have room, just lower the existing seal by removing the metal strip and moving the seal down and re-attach the metal strip thru new holes in the seal and back into the original holes in the camper.
Old 04-07-2015, 02:53 PM   #13
Wanna Be Camper
SaskCampers's Avatar
Thanks for the pdf.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-07-2015, 03:02 PM   #14
That's a good idea, never thought of that, I didn't see a topper so that would be easier really....Your good Old Man
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-14-2015, 08:45 AM   #15
Wanna Be Camper
That was my first thought as well, but it appears the seal is already right at the edge of the opening. Looking at the slide with it in, it appears the slide is actually down about 1/2 inch as the lower skirt where it curves under the side is down from the lower edge of the side by about 3/4". The slide has a through the frame slide mechanism that does not appear to be adjustable up and down and even if it did would that not move the slide up from the seal that seals the bottom of the slide?
John & Deb
factory, flagstaff, rockwood
