Old 02-03-2017, 11:28 AM   #1
frostriver's Avatar
Flagstaff Stock Tires
Expecting delivery of a new 832 BHIKWS in early March. Was curious if anyone has opinions on the stock tires and/or any success negotiating an upgrade from the factory through the dealer. If so, what would be the recommended upgrade?
frostriver is offline   Reply With Quote
Old 02-05-2017, 11:47 AM   #2
I have the rockwood 8329SS which is the same as the Flagstaff 832IKBS. Yours seems to similar to these as far as size and weight. I switched from factory C load tires to Maxxis D load. This has improved the handling of the TT. It does not bounce and wobble like it did. I don't have any experiences with working with dealer as I did this after a year after purchase because the weight of TT nearly maxed out tires capacity. I truly believe one tire was overloaded it always looked more squashed than the others.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 02-05-2017, 12:43 PM   #3
frostriver's Avatar
Thanks for the info! The dealer rep states that it will come with D rated tires. So, I asked if it was possible to factory or dealer upgrade to E's. No and No. it's hard to believe they would ever put C on these. Seems like it could be a potential liability, certainly if under rated for GVWR. Another list item for the PDI along with axle rating!
Old 02-05-2017, 01:21 PM   #4
SailorSam20500's Avatar
Yup, mine came with the D-rated tires. They are posted as speed rating L max 75 mph. Didn't try getting anything different, I used my ammo to get the couch deleted for credit.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 02-05-2017, 01:25 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
Agree with the upgrade. Normal air pressure for "C" rated tires is 55 psi, for "D" rated it should be 80 psi.
donanddona is offline   Reply With Quote
Old 02-05-2017, 01:28 PM   #6
Normal pressure for C is 50 and D is 65. E is 80.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-05-2017, 01:35 PM   #7
My ST225/75R15 LRD tires have a spec of 65 PSI, Looks lie all the Lions Head / Castle Rock D rated tires are 65PSI. Load range E is 80 PSI.
Al
S.E. Mich.
Old 03-10-2017, 11:58 AM   #8
update
I just bought my 5th and will be changing them out for Maxxis tires before going out this summer. They are the Maxxis 800 series they are rated E, these tire are made for 5th and they have a good reliability factor., I have heard a lot of bad info on the castle rock brand that came with my trailer would stay away from them.
bemilner is offline   Reply With Quote
Old 03-10-2017, 12:05 PM   #9
frostriver's Avatar
Thanks for the info! I'll check the brand next Wednesday when we take delivery.
Bought a good jack that will give me some confidence to make it one year on the stock D rated ones before upgrading next spring before my bumper to bumper warranty expires.
Old 03-10-2017, 12:12 PM   #10
jack
Good ideal on the jack, I have a 16 ton jack which I have carry with me for 40 years of camping never had to use it until last year. Had flat, call AAA the guy came out with a car jack we had a good laugh, he was thankful that I had a jack. lol
Old 03-10-2017, 12:26 PM   #11
Georgia Rally Coordinator
aceinspp's Avatar
My Good year tires rated for 65# air max speed 65 I'm good to go. My tt came with C rated china bombs sure got rid of them the same day. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 03-10-2017, 08:45 PM   #12
What country is stamped on the on your Goodyear's?
Old 03-11-2017, 10:14 PM   #13
Too old to be too smart
SpringerPop's Avatar
In reality, none of us should want to take delivery of a new trailer with the factory-installed tires.
There is no way to determine what degree of care the delivery driver had for them, and they may have suffered outright abuse in transit to your dealer.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
flagstaff, tire, tires
